Hello all,
as I was calling smart.available()
, I set up some logging which I piped to a file.
When I first restarted rockstor services, it logged SMART info for two HDD disks, but not for the NVMe SSD disk. I waited a bit and then killed the service.
I’ve tried again. This time I set up tail -f log
in another tty session.
When trying to kill tail
with CTRL-C, my kernel panicked. It didnt respond to keyboard as well.
I have taken a picture of the last few lines of the kernel panic before forcefully rebooting.
Kernel panicked again, this time at boot time and I took a picture as well. This time it seemed like a soft lockup, because the keys worked. The last line said something about “Fixing recursive fault but reboot is needed!”
So I rebooted again.
This time Rockstor is up and running.
My question is: where can I find the kernel panic logs?
/var/log/dmesg
only holds the log of the latest, successful boot. There are no rotated dmesg files here.
/var/crash
is empty.
Question #2 is finding out what happened.
Can you help? Should I talk to openSUSE folks?
This is a brand new PC. I have run some tests on RAM and disks before installing Rockstor, and no problems were found.
Thanks!
EDIT: I’m getting constant CPU stalling kernel-panic-like messages, mentions about postgres, gunicorn, so I am shutting the PC down now, because I need to go.
I wanna try booting without starting the rockstor services (which may cause this behaviour?). Is that possible?
