[SOLVED] New System Shell under 3.8.15-0 not working
After the silent upgrade to stable 3.8.15-0 and a reboot I wanted to try the new “system shell” that has been also requested by me…pressing the button/link, nothing happens (only spinning blue arrows appear, like after pressing update rock-ons button).
Any idea?
thx
Hi @glenngould,
did you turn on shell service??
No - I was not aware of this new service “turn on”, now it works:slight_smile:
Thanks @glenngould,
happy to read it’s all ok :smiley: (I was already thinking about a possible bug and new coding :scream: )
Marking this as solved:
By default Shellinabox service (yep, it’s a system service!) is disabled
M.
THX
At least a pop-up/message “you need to enable the services first” in order to give you a hint would be nice
:+1:
You’ re right, adding on issue to act like other services (while opening load if service is running or show service switch if turned off)
M.
