[SOLVED] Not using downloaded repomd.xml because it is older than what we have
Rockstor is driving me crazy today with an email every hour sounding like this:
/etc/cron.hourly/0yum-hourly.cron:
Not using downloaded repomd.xml because it is older than what we have:
Current : Sun May 14 23:27:47 2017
Downloaded: Sat May 13 04:08:57 2017
How do I fix / stop this?
Hi @KarstenV,
you can try a yum clean all then perform updates again
Mirko
Thanks.
The error seemed to fix itself during the day, not receiving hourly mails anymore :slight_smile:
But I’ll try to remember your helpfull post if the problem shows up again.
Getting the same, so will try the above. But can we build a process to fix this without the operator going to the shell? I don’t think messing with the OS is safe for some users.
Current : Mon May 22 08:47:55 2017
Downloaded: Mon May 15 09:18:04 2017
