my question is can i install config file and data file on two different drives
@kenneth_mccombs The quick answer is yes if your docker container / app supports this split then it can also be implimented in Rock-ons which are simply light gui informing wrappers around docker image definition files.
I see you have marked this thread as [Solved] but just wanted to round it off with a link to the rockon-registry GitHub repo and it’s README.md guide on creating your own Rock-ons.
There is also a Rock-ons (Docker Plugins) section in the official docs.
