[SOLVED - Samba Segmentation Fault - Dupe] Error while validating time servers(1.de.pool.ntp.org). Check your input and try again.. Lower level exception: Error running a command. cmd
[write here]
I tryied to add an ntp server. the server 1.de.pool.ntp.org is valid but doesnt get accepted, see error.
File “/opt/rockstor/src/rockstor/smart_manager/views/ntp_service.py”, line 58, in post
out, err, rc = run_command(cmd)
File “/opt/rockstor/src/rockstor/system/osi.py”, line 109, in run_command
CommandException: Error running a command. cmd = [‘/usr/sbin/ntpdate’, ‘1.de.pool.ntp.org’]. rc = -11. stdout = [‘’]. stderr = [‘’]
Hi @g6094199, can you please try this server:
ntp1.inrim.it
next step, from shell run cat /etc/nsswitch.conf | grep hosts and please post here your output
Mirko
Nope, doesnt work either:
File “/opt/rockstor/src/rockstor/system/osi.py”, line 104, in run_command
CommandException: Error running a command. cmd = [‘/usr/sbin/ntpdate’, ‘ntp1.inrim.it’]. rc = 1. stdout = [‘’]. stderr = [‘11 Jan 18:15:02 ntpdate[12033]: no server suitable for synchronization found’, ‘’]
cat /etc/nsswitch.conf | grep hosts: hosts: files dns
Can you ping ntp servers? no -> dns missing?
yes -> we have to check from shell
ntpdate 1.de.pool.ntp.org
ntpdate -d 1.de.pool.ntp.org
ntpdate -u 1.de.pool.ntp.org
M.
hi
no problem im very familar with the cli.
ping 1.de.pool.ntp.org
PING 1.de.pool.ntp.org (139.59.142.43) 56(84) bytes of data.
64 bytes from rot.fi (139.59.142.43): icmp_seq=1 ttl=59 time=15.4 ms
[root@rockstor ~]# kill 1777 (was ntpd)
[root@rockstor ~]# ps ax|grep ntp
11608 pts/0 S+ 0:00 grep --color=auto ntp
[root@rockstor ~]# ntpdate 1.de.pool.ntp.org
11 Jan 19:50:04 ntpdate[11609]: adjust time server 46.165.212.204 offset 0.011984 sec
[root@rockstor ~]# ntpdate -d 1.de.pool.ntp.org
11 Jan 19:50:24 ntpdate[11612]: ntpdate 4.2.6p5@1.2349-o Mon Nov 14 18:25:09 UTC 2016 (1)
Looking for host 1.de.pool.ntp.org and service ntp
host found : gir.theapt.org
transmit(81.209.183.113)
receive(81.209.183.113)
transmit(213.95.200.109)
receive(213.95.200.109)
transmit(213.172.105.106)
receive(213.172.105.106)
transmit(78.47.170.30)
receive(78.47.170.30)
server 81.209.183.113, port 123
stratum 3, precision -6, leap 00, trust 000
refid [81.209.183.113], delay 0.05777, dispersion 0.00215
transmitted 4, in filter 4
reference time: dc20f974.df35bfff Wed, Jan 11 2017 19:35:32.871
originate timestamp: dc20fcf7.365c5fff Wed, Jan 11 2017 19:50:31.212
transmit timestamp: dc20fcf7.353cf4e8 Wed, Jan 11 2017 19:50:31.207
filter delay: 0.06308 0.06461 0.05777 0.05876
0.00000 0.00000 0.00000 0.00000
filter offset: 0.001297 0.000889 -0.00376 -0.00437
0.000000 0.000000 0.000000 0.000000
offset -0.003765
server 213.95.200.109, port 123
stratum 2, precision -22, leap 00, trust 000
refid [213.95.200.109], delay 0.03336, dispersion 0.00217
reference time: dc20f76d.411777df Wed, Jan 11 2017 19:26:53.254
originate timestamp: dc20fcf7.67dbe02d Wed, Jan 11 2017 19:50:31.405
transmit timestamp: dc20fcf7.686cf069 Wed, Jan 11 2017 19:50:31.407
filter delay: 0.03912 0.04037 0.03336 0.03456
filter offset: -0.00105 -0.00150 -0.00605 -0.00677
offset -0.006057
server 213.172.105.106, port 123
stratum 2, precision -20, leap 00, trust 000
refid [213.172.105.106], delay 0.03368, dispersion 0.00215
reference time: dc20fbdf.3aa4a850 Wed, Jan 11 2017 19:45:51.229
originate timestamp: dc20fcf7.9bad7c71 Wed, Jan 11 2017 19:50:31.608
transmit timestamp: dc20fcf7.9ba56141 Wed, Jan 11 2017 19:50:31.607
filter delay: 0.03929 0.04077 0.03368 0.03476
filter offset: 0.001202 0.000749 -0.00382 -0.00449
offset -0.003821
server 78.47.170.30, port 123
stratum 2, precision -23, leap 00, trust 000
refid [78.47.170.30], delay 0.03540, dispersion 0.00214
reference time: dc20f6b2.b7af5f56 Wed, Jan 11 2017 19:23:46.717
originate timestamp: dc20fcf7.cebc93e5 Wed, Jan 11 2017 19:50:31.807
transmit timestamp: dc20fcf7.ced105e8 Wed, Jan 11 2017 19:50:31.807
filter delay: 0.04126 0.04237 0.03540 0.03662
filter offset: -0.00018 -0.00064 -0.00525 -0.00587
offset -0.005256
11 Jan 19:50:31 ntpdate[11612]: adjust time server 213.95.200.109 offset -0.006057 sec
[root@rockstor ~]# ntpdate -u 1.de.pool.ntp.org
11 Jan 19:50:41 ntpdate[11614]: adjust time server 213.95.200.109 offset -0.009093 sec
After that i tried to add the NTP sever to the web-if again and it worked! maybe there is a problenm with the ntpd, not beeing stoped correctly. i couldnt stop it with systemctl thats why i killed it.
now its status is:
[root@rockstor ~]# systemctl status ntpd
● ntpd.service - Network Time Service
Loaded: loaded (/usr/lib/systemd/system/ntpd.service; enabled; vendor preset: disabled)
Active: active (running) since Mi 2017-01-11 19:52:38 CET; 2min 44s ago
Main PID: 11817 (ntpd)
CGroup: /system.slice/ntpd.service
└─11817 /usr/sbin/ntpd -u ntp:ntp -g
Jan 11 19:52:38 rockstor.wvk ntpd[11817]: Listen and drop on 1 v6wildcard :: UDP 123
Jan 11 19:52:38 rockstor.wvk ntpd[11817]: Listen normally on 2 lo 127.0.0.1 UDP 123
Jan 11 19:52:38 rockstor.wvk ntpd[11817]: Listen normally on 3 eth0 192.168.115.22 UDP 123
Jan 11 19:52:38 rockstor.wvk ntpd[11817]: Listen normally on 4 lo ::1 UDP 123
Jan 11 19:52:38 rockstor.wvk ntpd[11817]: Listen normally on 5 eth0 fe80::5054:ff:fef3:b661 UDP 123
Jan 11 19:52:38 rockstor.wvk ntpd[11817]: Listening on routing socket on fd #22 for interface updates
Jan 11 19:52:38 rockstor.wvk ntpd[11817]: 0.0.0.0 c016 06 restart
Jan 11 19:52:38 rockstor.wvk ntpd[11817]: 0.0.0.0 c012 02 freq_set kernel 0.000 PPM
Jan 11 19:52:38 rockstor.wvk ntpd[11817]: 0.0.0.0 c011 01 freq_not_set
Jan 11 19:52:39 rockstor.wvk ntpd[11817]: 0.0.0.0 c614 04 freq_mode
after i restarted it in the gui.
hi!
Since im having some other problems to i played around with the system.
disabled ntp rebooted, tried to restart ntp → same error.
now it tried to ping the ntp servers and an “memory access error” occurs (“speicherzugriffsfehler” in german)
[root@rockstor ~]# route
Kernel IP Routentabelle
Ziel Router Genmask Flags Metric Ref Use Iface
Speicherzugriffsfehler
[root@rockstor ~]# ping 1.pool.ntp.org
so i guess there is another problem beeing involved.
this is a freshly installed VM with a 3.8-15 cd from sf and online updated to 3.8.16-6
did also an fresh install with the same error.
now it try to reinstall with the lastest 3.8-16-1 to see if anything changes.
Hi @g6094199,
Speicherzugriffsfehler is Segmentation fault, what I suspected on my previuous message asking if you can ping
This is a CentOS related issue currently with tracking over CentOS and Samba too
Solution:
on that forum link there’s a message with a trick to have ping and ntp running
Please note till Samba update from CentOS won’t be available, on every reboot you’ll have to manually start ntp service
Waiting your updates/checks :slight_smile:
M.
THX Mirko!
i did the easy fix and reinstalled with 3.8-15 and will do no updated till its fixed :wink:
Well @g6094199, you’d better stay on 3.8-16 (except on reboots you won’t suffer that CentOS bug on others)
M.
To all please update with yum update, major updates fixing samba segmentation fault over name resolution
M.
sorry no.
only therse updates are pushed and they dont fix the problem:
(1/3): bind-libs-lite-9.9.4-38.el7_3_9.9.4-38.el7_3.1.x86_64.drpm | 149 kB 00:00:00
(2/3): bind-license-9.9.4-38.el7_3.1.noarch.rpm | 83 kB 00:00:00
(3/3): rockstor-3.8.16-8.x86_64.rpm
will try again tomorrow…
Hi @g6094199,
Rockstor yum running with fastestmirror plugin so maybe your current mirror till without new packages (guessing)
M.
Edit: try with yum clean all && yum update
yep that fixed it.
i’m more of a debian guy so i wonder why yum doesnt pull the repo info without cleaning the cached data…
anyway
thx!
Hi @g6094199,
I’m a Debian guy too and I’m pretty sure yum has a kind of caching over repositories metadata (probably expiring every day?!?)
M.
