I tried adding a new using one of my former share names via the UI, and it seemed to nuke the 3 shares that were working from the clients (but invisible in the UI).
So I went in and added everything back, and they are listed. I restarted SMB and they are still there.
I rebooted and they are fine now too. I’m not sure what happened but we’ll see if they persist this time.
Hi @xantonin,
happy to hear all seems ok. Not so happy about nuked 3 shares, but we hadn’t a different way to test/solve: on every samba share add via WEB UI Rockstor cycle samba shares in Rockstor DB and rewrites smb.conf (so manually added shares get nuked!).
Please never modify smb.conf via shell because you’ll lose every change on first smb restart from web ui (full smb.conf rewrite).
With current infos I’m not able to explain why you had this issue, but marking this as solved
M.
