Hi @schakrava ,
once again we have an issue on separate services like on #1556
Issue found by Mahmoud user forum on https://forum.rockstor.com/t/scheduled-snapshots-stopped-running/2434
He tried to get further info (once again thanks Mahmoud! :smiley: ), but didn't get any useful log - not his fault, check this:
- had a 1 minute snapshot task scheduled and had errors on every task
- no logging on `rockstor.log`
- had a check on mail and :tada:
**Issue part 1 - no LOGGING**
Message 1:
[omitted]
Subject: Cron <root@rockstone> /opt/build/bin/st-snapshot 6 \*-*-*-*-*-*
Content-Type: text/plain; charset=UTF-8
Auto-Submitted: auto-generated
Precedence: bulk
X-Cron-Env: <XDG_SESSION_ID=91>
X-Cron-Env: <XDG_RUNTIME_DIR=/run/user/0>
X-Cron-Env: <LANG=it_IT.UTF-8>
X-Cron-Env: <SHELL=/bin/bash>
X-Cron-Env: <PATH=/sbin:/bin:/usr/sbin:/usr/bin>
X-Cron-Env: <MAILTO=root>
[omitted]X-Cron-Env: <HOME=/root>
X-Cron-Env: <LOGNAME=root>
X-Cron-Env: <USER=root>
Date: Wed, 30 Nov 2016 23:33:01 +0100 (CET)
Status: RO
No handlers could be found for logger "scripts.scheduled_tasks.snapshot" <------ NO LOGGING!
**Issue part 2, missing models again**:
- had all `logger.something` moved to `logging.something` to avoid no logger handlers error and checked a suspicion
snapshot has always had same data_collector "bad habit" to use ORM and manually running `./st-snapshot 6 \*-*-*-*-*-*` confirmed it
```python
ERROR:root:Failed to create snapshot at shares/storage/snapshots/testsnap_201612010043
ERROR:root:Models aren't loaded yet.
File "/opt/build/src/rockstor/scripts/scheduled_tasks/snapshot.py", line 103, in main
if(delete(aw, share, stype, prefix, max_count)):
File "/opt/build/src/rockstor/scripts/scheduled_tasks/snapshot.py", line 64, in delete
name__startswith=prefix).order_by('-id')
File "/opt/build/eggs/Django-1.8.16-py2.7.egg/django/db/models/manager.py", line 127, in manager_method
File "/opt/build/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py", line 679, in filter
return self._filter_or_exclude(False, *args, **kwargs)
File "/opt/build/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py", line 697, in _filter_or_exclude
clone.query.add_q(Q(*args, **kwargs))
File "/opt/build/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/query.py", line 1310, in add_q
clause, require_inner = self._add_q(where_part, self.used_aliases)
File "/opt/build/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/query.py", line 1338, in _add_q
allow_joins=allow_joins, split_subq=split_subq,
File "/opt/build/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/query.py", line 1150, in build_filter
lookups, parts, reffed_expression = self.solve_lookup_type(arg)
File "/opt/build/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/query.py", line 1036, in solve_lookup_type
_, field, _, lookup_parts = self.names_to_path(lookup_splitted, self.get_meta())
File "/opt/build/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/query.py", line 1373, in names_to_path
if field.is_relation and not field.related_model:
File "/opt/build/eggs/Django-1.8.16-py2.7.egg/django/utils/functional.py", line 59, in __get__
res = instance.__dict__[self.name] = self.func(instance)
File "/opt/build/eggs/Django-1.8.16-py2.7.egg/django/db/models/fields/related.py", line 110, in related_model
apps.check_models_ready()
File "/opt/build/eggs/Django-1.8.16-py2.7.egg/django/apps/registry.py", line 131, in check_models_ready
raise AppRegistryNotReady("Models aren't loaded yet.")
AppRegistryNotReady: Models aren't loaded yet.
I suppose **scrubs tasks suffer same issues too** /EDIT : replica too?? I don't know, never had it running
M.
