Sonarr is not moving tv show
can someone help with this issue all of a sudden sonar quit moving my shows. Here are the logs for one of the shows. Thanks
Details
Message
Couldn’t import episode /downloads/completed/Incorporated.S01E05.720p.HDTV.x264-FLEET/Incorporated.S01E05.720p.HDTV.x264-FLEET.mkv: Access to the path is denied.
Exception
System.UnauthorizedAccessException: Access to the path is denied.
at System.IO.File.Move (System.String sourceFileName, System.String destFileName) <0x7f27d955a5c0 + 0x002f0> in :0
at NzbDrone.Common.Disk.DiskProviderBase.MoveFile (System.String source, System.String destination, Boolean overwrite) [0x000e3] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskProviderBase.cs:209
at NzbDrone.Common.Disk.DiskTransferService.TryMoveFileTransactional (System.String sourcePath, System.String targetPath, Int64 originalSize, DiskTransferVerificationMode verificationMode) [0x0008f] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:479
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, TransferMode mode, Boolean overwrite, DiskTransferVerificationMode verificationMode) [0x003c2] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:301
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, TransferMode mode, Boolean overwrite, Boolean verified) [0x0000e] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:185
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.TransferFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Tv.Series series, System.Collections.Generic.List1 episodes, System.String destinationFilePath, TransferMode mode) [0x0012c] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:118
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.MoveEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode) [0x0005e] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:80
at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode, Boolean copyOnly) [0x00113] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:64
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import (System.Collections.Generic.List1 decisions, Boolean newDownload, NzbDrone.Core.Download.DownloadClientItem downloadClientItem, ImportMode importMode) [0x00274] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:107
Hello Kenneth,
In order to help you more information is needed.
What UID is sonarr running under.
Can you list the owner of the downloads directory?
You also need to list the owner information on the target folder where sonarr should move the files.
You should use the console for this with the “ls -l [path]”
Also go into the rockstor UI and check what owner and permissions are set on the shares.
Are you using transmission BT?
