After upgrade to 3.8-14 my Squeezebox Rock-On does not start anymore.
I tried with uninstalling it and then re-install but the re-install does not complete.
I can see the following error in the Rockstor.log:
[22/Jun/2016 17:44:49] DEBUG [storageadmin.views.rockon_helpers:70] Attempted to remove a container(logitechsqueezebox). out: [‘’] err: [‘Error response from daemon: no such id: logitechsqueezebox’, ‘Error: failed to remove containers: [logitechsqueezebox]’, ‘’] rc: 1.
[22/Jun/2016 17:44:49] DEBUG [storageadmin.views.rockon_helpers:127] exception while installing the Rockon(19)
[22/Jun/2016 17:44:49] ERROR [storageadmin.views.rockon_helpers:128] Error running a command. cmd = [‘/usr/bin/docker’, ‘run’, ‘–log-driver=syslog’, ‘-d’, ‘–restart=unless-stopped’, ‘–name’, ‘logitechsqueezebox’, ‘-v’, ‘/mnt2/music:/media’, ‘-v’, ‘/etc/localtime:/etc/localtime:ro’, ‘-p’, ‘3483:3483/tcp’, ‘-p’, ‘3483:3483/udp’, ‘-p’, ‘9092:9090/tcp’, ‘-p’, ‘9000:9000/tcp’, ‘tdeckers/logitechmediaserver’]. rc = 1. stdout = [‘’]. stderr = [‘Error response from daemon: could not find image: no such id: 86bbc809233e5d2363e89e342c1819d6f45d4099ac9845ef11326b70fc775840’, ‘’]
File “/opt/rockstor/src/rockstor/storageadmin/views/rockon_helpers.py”, line 125, in install
globals().get(‘%s_install’ % rockon.name.lower(), generic_install)(rockon)
File “/opt/rockstor/src/rockstor/storageadmin/views/rockon_helpers.py”, line 216, in generic_install
run_command(cmd)
File “/opt/rockstor/src/rockstor/system/osi.py”, line 98, in run_command
CommandException: Error running a command. cmd = [‘/usr/bin/docker’, ‘run’, ‘–log-driver=syslog’, ‘-d’, ‘–restart=unless-stopped’, ‘–name’, ‘logitechsqueezebox’, ‘-v’, ‘/mnt2/music:/media’, ‘-v’, ‘/etc/localtime:/etc/localtime:ro’, ‘-p’, ‘3483:3483/tcp’, ‘-p’, ‘3483:3483/udp’, ‘-p’, ‘9092:9090/tcp’, ‘-p’, ‘9000:9000/tcp’, ‘tdeckers/logitechmediaserver’]. rc = 1. stdout = [‘’]. stderr = [‘Error response from daemon: could not find image: no such id: 86bbc809233e5d2363e89e342c1819d6f45d4099ac9845ef11326b70fc775840’, ‘’]
