Stuck on uninstall
not sure how to fix this all i did was press the unistall button
@zee-mot, hello again. I assume, after 2 hours it’s still stuck in uninstalling?
at the command line you could check whether the nextcloud container is still running using:
sudo docker ps (when using the WebUI, if you use something like PuTTY and log in as root, you won’t need the sudo).
I suspect, it is not, but if it were, then you can at least manually stop using:
sudo docker stop nextcloud
I also assume a page refresh is not taking care of the problem either?
You can force the removal of the Rockon using the command line with:
cd /opt/rockstor
poetry run delete-rockon Nextcloud-Official
And then refresh the Rockon page.
thank you for helping me again
