Hello,
I would like to ask for help.
Recently I add to my pool 2 new drives and balance it. However, after the system start freezing during writting. It did not happed before. The balance took more than 2 weeks, and also some updates were instaled (OS, kernel, …).
I am running system of 8x8TB SMR drives (I know there are discussed but they work perfektly fine in 6 drive raid6 configuration (write 120mb/s). Now , it is 8x8TB raid6, without any extra mount option, with compression (using it as archive).
The problem exactly is when I start copying on the system after few sec. the processes jump to 100% CPU and whole transfer freeze (or slow down on few kb/s). The most active processes are kworker and also copying tool (rsync or cp). After I stop process it is still freezed for 10min in case of rsync but in case of cp it unfreeze immedietly.
The read is much slower than before (20-40mb/s) but it did not freeze.
I am big newbie and really dont know what to test check or do. So I would like to humbly ask for help. If any more information would help I will be glad to supply them.
Linux 4.4.5-1.el7.elrepo.x86_64 #1 SMP Thu Mar 10 11:45:51 EST 2016 x86_64 x86_64 x86_64 GNU/Linux
Label: ‘rockstor_rockstor’ uuid: cd5f7a8b-3430-4e95-9591-b44b791bdbca
Total devices 1 FS bytes used 1.62GiB
devid 1 size 12.55GiB used 4.04GiB path /dev/sda3
Label: ‘pumabtrfs’ uuid: 82a7594c-46f2-4e20-b555-5acf2496971d
Total devices 8 FS bytes used 29.86TiB
devid 1 size 7.28TiB used 7.28TiB path /dev/sdb
devid 2 size 7.28TiB used 7.28TiB path /dev/sdc
devid 3 size 7.28TiB used 7.28TiB path /dev/sdd
devid 4 size 7.28TiB used 7.28TiB path /dev/sde
devid 5 size 7.28TiB used 7.28TiB path /dev/sdf
devid 6 size 7.28TiB used 7.28TiB path /dev/sdg
devid 7 size 7.28TiB used 7.28TiB path /dev/sdh
devid 8 size 7.28TiB used 7.28TiB path /dev/sdi
Data, RAID6: total=43.62TiB, used=29.81TiB
System, RAID6: total=96.00MiB, used=2.44MiB
Metadata, RAID6: total=49.50GiB, used=48.59GiB
GlobalReserve, single: total=512.00MiB, used=0.00B
