System hangs on reboot
I have looked a few different times here on the forums and I haven’t found my exact problem yet.
When restarting the server from either the web interface or SSH it will just hang while loading the OS… At one point it was so bad that I was trying to load different Kernels. I would have to look at which one I loaded to give exact version numbers but it was 3.x. Of course nothing worked using that outdated kernel so I reset the machine again via web ui and it loaded back into the current kernel lightning fast and everything was fine. I am not sure where to look in the system for logs that might help me out on this one. Suggestions?
-Nick
Same thing happens to me as well, i reset or hard boot it again and it comes back up. It happens when i try to reboot via web gui and through the command linie init 6.
