Perhaps that’s due to the disjoint way Rockstor uses yum (like many automated update solutions). The actual update of the caches is handled by yum-cron, which is run hourly and daily. Although I haven’t looked at the Rockstor source which handles the updates, I would guess that it runs “yum -C check-update” to check for updates and “yum -C update” to install them. That -C forces yum to run from the local caches, without querying any repos, so no hang-up on failed remotes.
To bring this topic up again.
I’m running into this problem again. Internet access is fine. Did a “yum clean all && yum update”, but all i get is
[root@rockstor-nas ~]# yum clean all && yum update
Geladene Plugins: changelog, fastestmirror
Quellen werden aufgeräumt:Rockstor-Testing base elrepo epel extras rockstor updates
Cleaning up everything
Cleaning up list of fastest mirrors
http://rockstor.com/rockrepo-testing/repodata/repomd.xml: [Errno 12] Timeout on http://updates.rockstor.com:8999/rockstor-testing/repodata/repomd.xml: (28, ‘Connection timed out after 30822 milliseconds’)
Anderer Spiegelserver wird versucht.
http://rockstor.com/rockrepo-testing/repodata/repomd.xml: [Errno 12] Timeout on http://updates.rockstor.com:8999/rockstor-testing/repodata/repomd.xml: (28, ‘Connection timed out after 30819 milliseconds’)
http://rockstor.com/rockrepo-testing/repodata/repomd.xml: [Errno 12] Timeout on http://updates.rockstor.com:8999/rockstor-testing/repodata/repomd.xml: (28, ‘Connection timed out after 30816 milliseconds’)
http://rockstor.com/rockrepo-testing/repodata/repomd.xml: [Errno 12] Timeout on http://updates.rockstor.com:8999/rockstor-testing/repodata/repomd.xml: (28, ‘Connection timed out after 30821 milliseconds’)
http://rockstor.com/rockrepo-testing/repodata/repomd.xml: [Errno 12] Timeout on http://updates.rockstor.com:8999/rockstor-testing/repodata/repomd.xml: (28, ‘Connection timed out after 30818 milliseconds’)
http://rockstor.com/rockrepo-testing/repodata/repomd.xml: [Errno 12] Timeout on http://updates.rockstor.com:8999/rockstor-testing/repodata/repomd.xml: (28, ‘Connection timed out after 30817 milliseconds’)
http://rockstor.com/rockrepo-testing/repodata/repomd.xml: [Errno 12] Timeout on http://updates.rockstor.com:8999/rockstor-testing/repodata/repomd.xml: (28, ‘Connection timed out after 30823 milliseconds’)
http://rockstor.com/rockrepo-testing/repodata/repomd.xml: [Errno 12] Timeout on http://updates.rockstor.com:8999/rockstor-testing/repodata/repomd.xml: (28, ‘Connection timed out after 30812 milliseconds’)
One of the configured repositories failed (Subscription channel for testing updates),
and yum doesn’t have enough cached data to continue. At this point the only
safe thing yum can do is fail. There are a few ways to work “fix” this:
1. Contact the upstream for the repository and get them to fix the problem.
2. Reconfigure the baseurl/etc. for the repository, to point to a working upstream. This is most often useful if you are using a newer distribution release than is supported by the repository (and the packages for the previous distribution release still work).
3. Run the command with the repository temporarily disabled yum --disablerepo=Rockstor-Testing ...
4. Disable the repository permanently, so yum won't use it by default. Yum will then just ignore the repository until you permanently enable it again or use --enablerepo for temporary usage:
yum-config-manager --disable Rockstor-Testing or subscription-manager repos --disable=Rockstor-Testing
5. Configure the failing repository to be skipped, if it is unavailable. Note that yum will try to contact the repo. when it runs most commands, so will have to try and fail each time (and thus. yum will be be much slower). If it is a very temporary problem though, this is often a nice compromise:
yum-config-manager --save --setopt=Rockstor-Testing.skip_if_unavailable=true
failure: repodata/repomd.xml from Rockstor-Testing: [Errno 256] No more mirrors to try.
