Unable to remove Rock-on
I have been working on getting my Rockstor server to do more of the tasks I have that require a computer to be active.
So I installed the Squeezebox Rock-on to try and make it the server for my trusty old Squeezebox Classic.
Installation went fine, and I let it sit there, to come back later and do some more configuration and testing.
But later when I came back, I had to reboot the machine, to install a new disk (I am in the progress of going from RAID 6 to RAID1, and need never bigger disks). This all went well, and the disk is being added as we speak.
But. the Squeezebox Rockon was not active:
Trying to start it does nothing. The bar goes from on back to off after about a second.
Hitting update gives this (after some time):
Traceback:
File “/opt/rockstor/src/rockstor/storageadmin/views/rockon.py”, line 105, in post
File “/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/transaction.py”, line 371, in inner
return func(*args, **kwargs)
File “/opt/rockstor/src/rockstor/storageadmin/views/rockon.py”, line 169, in _create_update_meta
File “/opt/rockstor/src/rockstor/storageadmin/util.py”, line 49, in handle_exception
raise RockStorAPIException(detail=e_msg, trace=traceback.format_exc())
RockStorAPIException: [‘Cannot add/remove container definitions for Plex as it is not in available state. Uninstall the Rock-on first and try again.’, ‘Traceback (most recent call last):\n File “/opt/rockstor/eggs/gunicorn-0.16.1-py2.7.egg/gunicorn/workers/sync.py”, line 34, in run\n client, addr = self.socket.accept()\n File “/usr/lib64/python2.7/socket.py”, line 202, in accept\n sock, addr = self._sock.accept()\nerror: [Errno 11] Resource temporarily unavailable\n’]
Which to me is mostly meaningless. It looks as if it thinks I’m trying to remove Plex or something?
I have not, and Plex is running and works.
I have tried to Uninstall Squeezebox, to try and reinstall, but nothing seems to happen
It seems I hit a bug.
What info do you guys need to get me going?
Edit:
It seems I am also unable to stop the Plex service.
Well a reboot seems to have solved it.
At least both Rock-ons are running now.
