I’m reading about how to properly try to get this updated in the repository still, but thought I’d post it here in the meantime for anyone who might find it useful. I was personally having issues getting the current rock-on running.
Difference is using the linuxserver.io docker for unifi, adding the ports for speedtest and UBNT discovery, updating the volume mapping and adding UID and GID.
"Ubiquiti Unifi": {
"containers": {
"unifi": {
"image": "linuxserver/unifi",
"launch_order": 1,
"ports": {
"8080": {
"description": "Port for UAP to inform controller (HTTP redirect for WebUI). Suggested default: 8080",
"host_default": 8080,
"label": "Redirect to WebUI",
"protocol": "tcp",
"ui": true
"8443": {
"description": "Port for WebUI and API. Suggested default: 8443",
"host_default": 8443,
"label": "HTTPS WebUI",
"protocol": "tcp",
"ui": false
"8081": {
"description": "Management Port. Suggested default: 8081",
"host_default": 8081,
"label": "Management Port",
"protocol": "tcp",
"ui": false
"8880": {
"description": "Redirect to Portal. Suggested default: 8880",
"host_default": 8880,
"label": "Redirect to Portal",
"protocol": "tcp",
"ui": false
"8843": {
"description": "portal redirect port for HTTPs. Suggested default: 8843",
"host_default": 8843,
"label": "HTTPS Portal",
"protocol": "tcp",
"ui": false
"3478": {
"description": "STUN Port. Suggested default: 3478",
"host_default": 3478,
"label": "STUN Port",
"protocol": "udp",
"ui": false
"6790": {
"description": "Speed Test. Suggested default: 6790",
"host_default": 6790,
"label": "Speed Test",
"protocol": "tcp",
"ui": false
"10001": {
"description": "UBNT Discovery. Suggest default 10001",
"host_default": 10001,
"label": "UBNT Discovery",
"protocol": "udp",
"ui": false
"volumes": {
"/config": {
"description": "Choose a Share for Unifi Controller configuration. Eg: create a Share called unifi-config for this purpose alone.",
"label": "Config Storage"
"environment": {
"PUID": {
"description": "Enter a valid UID to run Unifi as. It must have full permissions to all Shares mapped in the previous step.",
"label": "UID to run Unifi as.",
"index": 1
"PGID": {
"description": "Enter a valid GID to use along with the above UID. It(or the above UID) must have full permissions to all Shares mapped in the previous step.",
"label": "GID to run Unifi as.",
"index": 2
"description": "Unifi Access Point controller",
"more_info": "This is a containerized version of Ubiquiti Network's Unifi Controller.",
"volume_add_support": false,
"ui": {
"slug": ""
"website": "https://hub.docker.com/r/linuxserver/unifi/",
"version": "latest"
