Hi All,
I wanted a nice way to stop remembering ports, and having the Pi-Hole rockon + the native Nginx server seemed like a reasonable way to do it.
The scripts are configured to run all services as hosts under a non-existant gTLD ‘.home’. Other configurations should be fairly self-explanatory.
The following method will factor in Rockstor potentially updating the nginx config, and ensure pi-hole is running before making changes.
/etc/crontab
* * * * * root /root/scripts/nginx-proxy.sh
* * * * * root /root/scripts/pi-hole-update.sh
#!/usr/bin/bash
# Check for inclide directory in rockstor nginx config
grep -q conf.d /opt/rockstor/etc/nginx/nginx.conf || {
# Add config in place, create backup nginx.conf.bak
perl -plni.bak -e 'print "\tinclude\t\t/root/conf.d/\*;\n" if(/\s+server \{/)' /opt/rockstor/etc/nginx/nginx.conf;
# Restart the service
systemctl restart rockstor.service || {
# Failed! Retrieve backup and restart again
mv /opt/rockstor/etc/nginx/nginx.conf.bak /opt/rockstor/etc/nginx.conf;
systemctl restart rockstor.service;
#!/usr/bin/bash
# Create an associative array of host entries
mainIP='192.168.0.7'
declare -A aa hosts
hosts=(
[tv]=$mainIP
[pihole]=$mainIP
[sonarr]=$mainIP
[nzbget]=$mainIP
[torrent]=$mainIP
[couchpotato]=$mainIP
# Ensure pi-hole rockon is running
docker container ls | grep -q pi-hole-diginc || { echo "Failed to identify running Pi-Hole rockon instance"; exit 1; }
changes=0
for host in "${!hosts[@]}"; do
# Check for host entry in docker's hosts file
{ docker container exec pi-hole-diginc grep -q "${host}\.home" /etc/hosts; } || {
# If missing, add it and log the change
docker container exec pi-hole-diginc bash -c "echo -e \"${hosts[$host]}\t${host}.home\" >> /etc/hosts";
changes=$(($changes + 1));
done
# If changes were made, restart dnsmasq to reload config.
[ "$changes" -lt "1" ] || docker container exec pi-hole-diginc service dnsmasq restart
/root/conf.d/custom.conf
# Couchpotato
server {
listen 80;
server_name couchpotato.home cp.home;
location / {
proxy_pass http://localhost:5050;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
# Sonarr
server {
listen 80;
server_name sonarr.home;
location / {
proxy_pass http://localhost:8989;
# NZBGet
server {
listen 80;
server_name nzbget.home dl.home;
location / {
proxy_pass http://localhost:6789;
# Transmission
server {
listen 80;
server_name torrent.home;
location / {
proxy_pass http://localhost:9091;
# Pi-Hole
server {
listen 80;
server_name pi.hole;
location / {
proxy_pass http://localhost:83/admin/;
# Plex
upstream plex-upstream {
server localhost:32400;
server {
listen 80;
server_name tv.home;
location / {
if ($http_x_plex_device_name = '') {
rewrite ^/$ http://$http_host/web/index.html;
proxy_redirect off;
proxy_set_header Host $http_host;
proxy_pass http://plex-upstream;
Comments/constructive criticism welcome.
