rockstor:~ # journalctl
Feb 07 09:00:00 localhost kernel: Booting Linux on physical CPU 0x0000000000 [0x410fd083]
Feb 07 09:00:00 localhost kernel: Linux version 5.14.21-150400.24.46-default (geeko@buildhost) (gcc (SUSE Linux) 7.5.0, GNU ld (GNU >
Feb 07 09:00:00 localhost kernel: random: fast init done
Feb 07 09:00:00 localhost kernel: Machine model: Raspberry Pi 4 Model B Rev 1.2
Feb 07 09:00:00 localhost kernel: efi: EFI v2.80 by Das U-Boot
Feb 07 09:00:00 localhost kernel: efi: RTPROP=0x3cb21040 SMBIOS=0x3cb1d000 RNG=0x26b6d040 MEMRESERVE=0x26b6c040
Feb 07 09:00:00 localhost kernel: efi: seeding entropy pool
Feb 07 09:00:00 localhost kernel: Reserved memory: created CMA memory pool at 0x000000002c000000, size 64 MiB
Feb 07 09:00:00 localhost kernel: OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Feb 07 09:00:00 localhost kernel: NUMA: No NUMA configuration found
Feb 07 09:00:00 localhost kernel: NUMA: Faking a node at [mem 0x0000000000000000-0x00000000fbffffff]
Feb 07 09:00:00 localhost kernel: NUMA: NODE_DATA [mem 0xfb7e5400-0xfb7e9fff]
Feb 07 09:00:00 localhost kernel: Zone ranges:
Feb 07 09:00:00 localhost kernel: DMA [mem 0x0000000000000000-0x000000003fffffff]
Feb 07 09:00:00 localhost kernel: DMA32 [mem 0x0000000040000000-0x00000000fbffffff]
Feb 07 09:00:00 localhost kernel: Normal empty
Feb 07 09:00:00 localhost kernel: Device empty
Feb 07 09:00:00 localhost kernel: Movable zone start for each node
Feb 07 09:00:00 localhost kernel: Early memory node ranges
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x0000000000000000-0x0000000000000fff]
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x0000000000001000-0x000000003cb1cfff]
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x000000003cb1d000-0x000000003cb1dfff]
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x000000003cb1e000-0x000000003cb20fff]
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x000000003cb21000-0x000000003cb23fff]
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x000000003cb24000-0x000000003cb24fff]
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x000000003cb25000-0x000000003cb28fff]
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x000000003cb29000-0x000000003df3ffff]
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x000000003df40000-0x000000003df4ffff]
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x000000003df50000-0x000000003dffffff]
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x000000003ef60000-0x000000003ef60fff]
Feb 07 09:00:00 localhost kernel: node 0: [mem 0x0000000040000000-0x00000000fbffffff]
Feb 07 09:00:00 localhost kernel: Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
Feb 07 09:00:00 localhost kernel: percpu: Embedded 30 pages/cpu s83992 r8192 d30696 u122880
Feb 07 09:00:00 localhost kernel: pcpu-alloc: s83992 r8192 d30696 u122880 alloc=30*4096
Feb 07 09:00:00 localhost kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Feb 07 09:00:00 localhost kernel: Detected PIPT I-cache on CPU0
Feb 07 09:00:00 localhost kernel: CPU features: detected: Spectre-v2
Feb 07 09:00:00 localhost kernel: CPU features: detected: Spectre-v3a
Feb 07 09:00:00 localhost kernel: CPU features: detected: Spectre-v4
Feb 07 09:00:00 localhost kernel: CPU features: detected: Spectre-BHB
Feb 07 09:00:00 localhost kernel: CPU features: kernel page table isolation forced ON by KASLR
Feb 07 09:00:00 localhost kernel: CPU features: detected: Kernel page table isolation (KPTI)
Feb 07 09:00:00 localhost kernel: CPU features: detected: ARM erratum 1742098
Feb 07 09:00:00 localhost kernel: CPU features: detected: ARM errata 1165522, 1319367, or 1530923
Feb 07 09:00:00 localhost kernel: Fallback order for Node 0: 0
Feb 07 09:00:00 localhost kernel: Built 1 zonelists, mobility grouping on. Total pages: 1007873
Feb 07 09:00:00 localhost kernel: Policy zone: DMA32
Feb 07 09:00:00 localhost kernel: Kernel command line: BOOT_IMAGE=/boot/Image-5.14.21-150400.24.46-default root=UUID=1fe18548-6cee-4>
Feb 07 09:00:00 localhost kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/Image-5.14.21-150400.24.46-default", will>
Feb 07 09:00:00 localhost kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Feb 07 09:00:00 localhost kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Feb 07 09:00:00 localhost kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
Feb 07 09:00:00 localhost kernel: software IO TLB: mapped [mem 0x0000000038b1d000-0x000000003cb1d000] (64MB)
Feb 07 09:00:00 localhost kernel: Memory: 905264K/4096004K available (14336K kernel code, 3334K rwdata, 11136K rodata, 6784K init, 1>
Feb 07 09:00:00 localhost kernel: random: get_random_u64 called from __kmem_cache_create+0x34/0x540 with crng_init=1
Feb 07 09:00:00 localhost kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Feb 07 09:00:00 localhost kernel: ftrace: allocating 44907 entries in 176 pages
Feb 07 09:00:00 localhost kernel: ftrace: allocated 176 pages with 3 groups
Feb 07 09:00:00 localhost kernel: trace event string verifier disabled
Feb 07 09:00:00 localhost kernel: Dynamic Preempt: none
Feb 07 09:00:00 localhost kernel: rcu: Preemptible hierarchical RCU implementation.
Feb 07 09:00:00 localhost kernel: rcu: RCU event tracing is enabled.
Feb 07 09:00:00 localhost kernel: rcu: RCU restricting CPUs from NR_CPUS=768 to nr_cpu_ids=4.
Feb 07 09:00:00 localhost kernel: Trampoline variant of Tasks RCU enabled.
Feb 07 09:00:00 localhost kernel: Rude variant of Tasks RCU enabled.
Feb 07 09:00:00 localhost kernel: Tracing variant of Tasks RCU enabled.
Feb 07 09:00:00 localhost kernel: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Feb 07 09:00:00 localhost kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Feb 07 09:00:00 localhost kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Feb 07 09:00:00 localhost kernel: Root IRQ handler: gic_handle_irq
Feb 07 09:00:00 localhost kernel: GIC: Using split EOI/Deactivate mode
Feb 07 09:00:00 localhost kernel: irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 10)
Feb 07 09:00:00 localhost kernel: arch_timer: cp15 timer(s) running at 54.00MHz (phys).
Feb 07 09:00:00 localhost kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795>
Feb 07 09:00:00 localhost kernel: sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
Feb 07 09:00:00 localhost kernel: random: crng init done
Feb 07 09:00:00 localhost kernel: Console: colour dummy device 80x25
Feb 07 09:00:00 localhost kernel: printk: console [tty0] enabled
Feb 07 09:00:00 localhost kernel: serial port 0 not yet initialized
Feb 07 09:00:00 localhost kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=54>
Feb 07 09:00:00 localhost kernel: pid_max: default: 32768 minimum: 301
Feb 07 09:00:00 localhost kernel: LSM: Security Framework initializing
Feb 07 09:00:00 localhost kernel: AppArmor: AppArmor initialized
Feb 07 09:00:00 localhost kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Feb 07 09:00:00 localhost kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Feb 07 09:00:00 localhost kernel: rcu: Hierarchical SRCU implementation.
Feb 07 09:00:00 localhost kernel: Remapping and enabling EFI services.
Feb 07 09:00:00 localhost kernel: smp: Bringing up secondary CPUs ...
Feb 07 09:00:00 localhost kernel: Detected PIPT I-cache on CPU1
Feb 07 09:00:00 localhost kernel: CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
Feb 07 09:00:00 localhost kernel: Detected PIPT I-cache on CPU2
Feb 07 09:00:00 localhost kernel: CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
Feb 07 09:00:00 localhost kernel: Detected PIPT I-cache on CPU3
Feb 07 09:00:00 localhost kernel: CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
Feb 07 09:00:00 localhost kernel: smp: Brought up 1 node, 4 CPUs
Feb 07 09:00:00 localhost kernel: SMP: Total of 4 processors activated.
Feb 07 09:00:00 localhost kernel: CPU features: detected: 32-bit EL0 Support
Feb 07 09:00:00 localhost kernel: CPU features: detected: 32-bit EL1 Support
Feb 07 09:00:00 localhost kernel: CPU features: detected: CRC32 instructions
Feb 07 09:00:00 localhost kernel: CPU: All CPU(s) started at EL2
Feb 07 09:00:00 localhost kernel: alternatives: patching kernel code
Feb 07 09:00:00 localhost kernel: node 0 deferred pages initialised in 50ms
Feb 07 09:00:00 localhost kernel: devtmpfs: initialized
Feb 07 09:00:00 localhost kernel: Registered cp15_barrier emulation handler
Feb 07 09:00:00 localhost kernel: Registered setend emulation handler
Feb 07 09:00:00 localhost kernel: KASLR enabled
Feb 07 09:00:00 localhost kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Feb 07 09:00:00 localhost kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Feb 07 09:00:00 localhost kernel: pinctrl core: initialized pinctrl subsystem
Feb 07 09:00:00 localhost kernel: SMBIOS 3.0 present.
Feb 07 09:00:00 localhost kernel: DMI: raspberrypi rpi/rpi, BIOS 2021.10 10/01/2021
Feb 07 09:00:00 localhost kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Feb 07 09:00:00 localhost kernel: DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
Feb 07 09:00:00 localhost kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Feb 07 09:00:00 localhost kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Feb 07 09:00:00 localhost kernel: audit: initializing netlink subsys (disabled)
Feb 07 09:00:00 localhost kernel: audit: type=2000 audit(0.070:1): state=initialized audit_enabled=0 res=1
Feb 07 09:00:00 localhost kernel: thermal_sys: Registered thermal governor 'fair_share'
Feb 07 09:00:00 localhost kernel: thermal_sys: Registered thermal governor 'bang_bang'
Feb 07 09:00:00 localhost kernel: thermal_sys: Registered thermal governor 'step_wise'
Feb 07 09:00:00 localhost kernel: thermal_sys: Registered thermal governor 'user_space'
Feb 07 09:00:00 localhost kernel: cpuidle: using governor ladder
Feb 07 09:00:00 localhost kernel: cpuidle: using governor menu
Feb 07 09:00:00 localhost kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Feb 07 09:00:00 localhost kernel: ASID allocator initialised with 32768 entries
Feb 07 09:00:00 localhost kernel: Serial: AMBA PL011 UART driver
Feb 07 09:00:00 localhost kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Feb 07 09:00:00 localhost kernel: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
Feb 07 09:00:00 localhost kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Feb 07 09:00:00 localhost kernel: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
Feb 07 09:00:00 localhost kernel: ACPI: Interpreter disabled.
Feb 07 09:00:00 localhost kernel: iommu: Default domain type: Passthrough
Feb 07 09:00:00 localhost kernel: vgaarb: loaded
Feb 07 09:00:00 localhost kernel: pps_core: LinuxPPS API ver. 1 registered
Feb 07 09:00:00 localhost kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Feb 07 09:00:00 localhost kernel: PTP clock support registered
Feb 07 09:00:00 localhost kernel: EDAC MC: Ver: 3.0.0
Feb 07 09:00:00 localhost kernel: Registered efivars operations
Feb 07 09:00:00 localhost kernel: ima: secureboot mode disabled
Feb 07 09:00:00 localhost kernel: NetLabel: Initializing
Feb 07 09:00:00 localhost kernel: NetLabel: domain hash size = 128
Feb 07 09:00:00 localhost kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
Feb 07 09:00:00 localhost kernel: NetLabel: unlabeled traffic allowed by default
Feb 07 09:00:00 localhost kernel: clocksource: Switched to clocksource arch_sys_counter
Feb 07 09:00:00 localhost kernel: VFS: Disk quotas dquot_6.6.0
Feb 07 09:00:00 localhost kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Feb 07 09:00:00 localhost kernel: AppArmor: AppArmor Filesystem Enabled
Feb 07 09:00:00 localhost kernel: pnp: PnP ACPI: disabled
Feb 07 09:00:00 localhost kernel: NET: Registered PF_INET protocol family
Feb 07 09:00:00 localhost kernel: IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
Feb 07 09:00:00 localhost kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
Feb 07 09:00:00 localhost kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
Feb 07 09:00:00 localhost kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
Feb 07 09:00:00 localhost kernel: TCP: Hash tables configured (established 32768 bind 32768)
Feb 07 09:00:00 localhost kernel: MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
Feb 07 09:00:00 localhost kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
Feb 07 09:00:00 localhost kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
Feb 07 09:00:00 localhost kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Feb 07 09:00:00 localhost kernel: NET: Registered PF_XDP protocol family
Feb 07 09:00:00 localhost kernel: PCI: CLS 0 bytes, default 64
Feb 07 09:00:00 localhost kernel: Trying to unpack rootfs image as initramfs...
Feb 07 09:00:00 localhost kernel: hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
Feb 07 09:00:00 localhost kernel: kvm [1]: IPA Size Limit: 44 bits
Feb 07 09:00:00 localhost kernel: kvm [1]: vgic interrupt IRQ9
Feb 07 09:00:00 localhost kernel: kvm [1]: Hyp mode initialized successfully
Feb 07 09:00:00 localhost kernel: Initialise system trusted keyrings
Feb 07 09:00:00 localhost kernel: Key type blacklist registered
Feb 07 09:00:00 localhost kernel: workingset: timestamp_bits=40 max_order=20 bucket_order=0
Feb 07 09:00:00 localhost kernel: zbud: loaded
Feb 07 09:00:00 localhost kernel: integrity: Platform Keyring initialized
Feb 07 09:00:00 localhost kernel: Freeing initrd memory: 72644K
Feb 07 09:00:00 localhost kernel: Key type asymmetric registered
Feb 07 09:00:00 localhost kernel: Asymmetric key parser 'x509' registered
Feb 07 09:00:00 localhost kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
Feb 07 09:00:00 localhost kernel: io scheduler mq-deadline registered
Feb 07 09:00:00 localhost kernel: io scheduler kyber registered
Feb 07 09:00:00 localhost kernel: io scheduler bfq registered
Feb 07 09:00:00 localhost kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Feb 07 09:00:00 localhost kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Feb 07 09:00:00 localhost kernel: bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
Feb 07 09:00:00 localhost kernel: printk: console [ttyS0] disabled
Feb 07 09:00:00 localhost kernel: fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 24, base_baud = 62499999) is a 16550
Feb 07 09:00:00 localhost kernel: printk: console [ttyS0] enabled
Feb 07 09:00:00 localhost kernel: Serial: AMBA driver
Feb 07 09:00:00 localhost kernel: msm_serial: driver initialized
Feb 07 09:00:00 localhost kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0
Feb 07 09:00:00 localhost kernel: bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
Feb 07 09:00:00 localhost kernel: libphy: Fixed MDIO Bus: probed
Feb 07 09:00:00 localhost kernel: mousedev: PS/2 mouse device common for all mice
Feb 07 09:00:00 localhost kernel: ledtrig-cpu: registered to indicate activity on CPUs
Feb 07 09:00:00 localhost kernel: efifb: probing for efifb
Feb 07 09:00:00 localhost kernel: efifb: framebuffer at 0x3e3cf000, using 8100k, total 8100k
Feb 07 09:00:00 localhost kernel: efifb: mode is 1920x1080x32, linelength=7680, pages=1
Feb 07 09:00:00 localhost kernel: efifb: scrolling: redraw
Feb 07 09:00:00 localhost kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
Feb 07 09:00:00 localhost kernel: Console: switching to colour frame buffer device 240x67
Feb 07 09:00:00 localhost kernel: fb0: EFI VGA frame buffer device
Feb 07 09:00:00 localhost kernel: hid: raw HID events driver (C) Jiri Kosina
Feb 07 09:00:00 localhost kernel: bcm2835-mbox fe00b880.mailbox: mailbox enabled
Feb 07 09:00:00 localhost kernel: drop_monitor: Initializing network drop monitor service
Feb 07 09:00:00 localhost kernel: NET: Registered PF_INET6 protocol family
Feb 07 09:00:00 localhost kernel: Segment Routing with IPv6
Feb 07 09:00:00 localhost kernel: RPL Segment Routing with IPv6
Feb 07 09:00:00 localhost kernel: registered taskstats version 1
Feb 07 09:00:00 localhost kernel: Loading compiled-in X.509 certificates
Feb 07 09:00:00 localhost kernel: Loaded X.509 cert 'SUSE Linux Enterprise Secure Boot Signkey: 0ac62b1f3f534271132586e29d3b1041591c>
Feb 07 09:00:00 localhost kernel: zswap: loaded using pool lzo/zbud
Feb 07 09:00:00 localhost kernel: page_owner is disabled
Feb 07 09:00:00 localhost kernel: Key type ._fscrypt registered
Feb 07 09:00:00 localhost kernel: Key type .fscrypt registered
Feb 07 09:00:00 localhost kernel: Key type fscrypt-provisioning registered
Feb 07 09:00:00 localhost kernel: cryptd: max_cpu_qlen set to 1000
Feb 07 09:00:00 localhost kernel: Key type encrypted registered
Feb 07 09:00:00 localhost kernel: AppArmor: AppArmor sha1 policy hashing enabled
Feb 07 09:00:00 localhost kernel: ima: No TPM chip found, activating TPM-bypass!
Feb 07 09:00:00 localhost kernel: Loading compiled-in module X.509 certificates
Feb 07 09:00:00 localhost kernel: ima: Allocated hash algorithm: sha256
Feb 07 09:00:00 localhost kernel: ima: No architecture policies found
Feb 07 09:00:00 localhost kernel: evm: Initialising EVM extended attributes:
Feb 07 09:00:00 localhost kernel: evm: security.selinux
Feb 07 09:00:00 localhost kernel: evm: security.SMACK64 (disabled)
Feb 07 09:00:00 localhost kernel: evm: security.SMACK64EXEC (disabled)
Feb 07 09:00:00 localhost kernel: evm: security.SMACK64TRANSMUTE (disabled)
Feb 07 09:00:00 localhost kernel: evm: security.SMACK64MMAP (disabled)
Feb 07 09:00:00 localhost kernel: evm: security.apparmor
Feb 07 09:00:00 localhost kernel: evm: security.ima
Feb 07 09:00:00 localhost kernel: evm: security.capability
Feb 07 09:00:00 localhost kernel: evm: HMAC attrs: 0x1
Feb 07 09:00:00 localhost kernel: uart-pl011 fe201000.serial: there is not valid maps for state default
Feb 07 09:00:00 localhost kernel: fe201000.serial: ttyAMA1 at MMIO 0xfe201000 (irq = 23, base_baud = 0) is a PL011 rev2
Feb 07 09:00:00 localhost kernel: serial serial0: tty port ttyAMA1 registered
Feb 07 09:00:00 localhost kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2021-09-30T19:21:03
Feb 07 09:00:00 localhost kernel: Freeing unused kernel memory: 6784K
Feb 07 09:00:00 localhost kernel: Run /init as init process
Feb 07 09:00:00 localhost kernel: with arguments:
Feb 07 09:00:00 localhost kernel: /init
Feb 07 09:00:00 localhost kernel: with environment:
Feb 07 09:00:00 localhost kernel: HOME=/
Feb 07 09:00:00 localhost kernel: TERM=linux
Feb 07 09:00:00 localhost kernel: BOOT_IMAGE=/boot/Image-5.14.21-150400.24.46-default
Feb 07 09:00:00 localhost systemd[1]: System time before build time, advancing clock.
Feb 07 09:00:00 localhost systemd[1]: systemd 249.15+suse.169.g1197409151 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR -IM>
Feb 07 09:00:00 localhost systemd[1]: Detected architecture arm64.
Feb 07 09:00:00 localhost systemd[1]: Running in initial RAM disk.
Feb 07 09:00:00 localhost systemd[1]: No hostname configured, using default hostname.
Feb 07 09:00:00 localhost systemd[1]: Hostname set to <localhost>.
Feb 07 09:00:00 localhost systemd[1]: Initializing machine ID from random generator.
Feb 07 09:00:00 localhost systemd[1]: Queued start job for default target Initrd Default Target.
Feb 07 09:00:00 localhost systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Feb 07 09:00:00 localhost systemd[1]: Reached target Local Encrypted Volumes.
Feb 07 09:00:00 localhost systemd[1]: Reached target Initrd /usr File System.
Feb 07 09:00:00 localhost systemd[1]: Reached target Local File Systems.
Feb 07 09:00:00 localhost systemd[1]: Reached target Path Units.
Feb 07 09:00:00 localhost systemd[1]: Reached target Slice Units.
Feb 07 09:00:00 localhost systemd[1]: Reached target Swaps.
Feb 07 09:00:00 localhost systemd[1]: Reached target Timer Units.
Feb 07 09:00:00 localhost systemd[1]: Listening on D-Bus System Message Bus Socket.
Feb 07 09:00:00 localhost systemd[1]: Listening on Open-iSCSI iscsid Socket.
Feb 07 09:00:00 localhost systemd[1]: Listening on Journal Socket (/dev/log).
Feb 07 09:00:00 localhost systemd[1]: Listening on Journal Socket.
Feb 07 09:00:00 localhost systemd[1]: Listening on udev Control Socket.
Feb 07 09:00:00 localhost systemd[1]: Listening on udev Kernel Socket.
Feb 07 09:00:00 localhost systemd[1]: Reached target Socket Units.
Feb 07 09:00:00 localhost systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
Feb 07 09:00:00 localhost systemd[1]: Starting Create List of Static Device Nodes...
Feb 07 09:00:00 localhost systemd[1]: Starting Journal Service...
Feb 07 09:00:00 localhost systemd[1]: Starting Load Kernel Modules...
Feb 07 09:00:00 localhost systemd[1]: Starting Setup Virtual Console...
Feb 07 09:00:00 localhost systemd[1]: Finished Create List of Static Device Nodes.
Feb 07 09:00:00 localhost systemd[1]: Starting Create Static Device Nodes in /dev...
Feb 07 09:00:00 localhost kernel: SCSI subsystem initialized
Feb 07 09:00:00 localhost systemd-journald[219]: Journal started
Feb 07 09:00:00 localhost systemd-journald[219]: Runtime Journal (/run/log/journal/99424e9f19ed4c3f82506bef2ed0cbd9) is 8.0M, max 76>
Feb 07 09:00:00 localhost systemd-modules-load[220]: Inserted module 'sg'
Feb 07 09:00:00 localhost systemd[1]: Started Journal Service.
Feb 07 09:00:00 localhost haveged[216]: haveged: command socket is listening at fd 3
Feb 07 09:00:01 localhost systemd[1]: Finished Load Kernel Modules.
Feb 07 09:00:01 localhost systemd[1]: Finished Create Static Device Nodes in /dev.
Feb 07 09:00:01 localhost systemd[1]: Starting Apply Kernel Variables...
Feb 07 09:00:01 localhost systemd[1]: Starting Create Volatile Files and Directories...
Feb 07 09:00:01 localhost systemd[1]: Finished Apply Kernel Variables.
Feb 07 09:00:01 localhost systemd[1]: Finished Create Volatile Files and Directories.
Feb 07 09:00:01 localhost systemd[1]: Finished Setup Virtual Console.
Feb 07 09:00:01 localhost systemd[1]: Starting dracut ask for additional cmdline parameters...
Feb 07 09:00:01 localhost systemd[1]: Finished dracut ask for additional cmdline parameters.
Feb 07 09:00:01 localhost systemd[1]: Starting dracut cmdline hook...
Feb 07 09:00:01 localhost dracut-cmdline[239]: dracut-15.4 dracut-055+suse.331.g05b9ccb7-150400.3.16.1
Feb 07 09:00:01 localhost dracut-cmdline[239]: Using kernel command line parameters: rd.driver.pre=btrfs BOOT_IMAGE=/boot/Image-5>
Feb 07 09:00:02 localhost kernel: Loading iSCSI transport class v2.0-870.
Feb 07 09:00:02 localhost kernel: iscsi: registered transport (tcp)
Feb 07 09:00:02 localhost kernel: iscsi: registered transport (qla4xxx)
Feb 07 09:00:02 localhost kernel: QLogic iSCSI HBA Driver
Feb 07 09:00:02 localhost kernel: libcxgbi:libcxgbi_init_module: Chelsio iSCSI driver library libcxgbi v0.9.1-ko (Apr. 2015)
Feb 07 09:00:02 localhost kernel: Chelsio T3 iSCSI Driver cxgb3i v2.0.1-ko (Apr. 2015)
Feb 07 09:00:02 localhost kernel: iscsi: registered transport (cxgb3i)
Feb 07 09:00:02 localhost kernel: Chelsio T4-T6 iSCSI Driver cxgb4i v0.9.5-ko (Apr. 2015)
Feb 07 09:00:02 localhost kernel: iscsi: registered transport (cxgb4i)
Feb 07 09:00:02 localhost kernel: cxgb4i:cxgb4i_init_module: cxgb4i dcb enabled.
Feb 07 09:00:02 localhost kernel: cnic: QLogic cnicDriver v2.5.22 (July 20, 2015)
Feb 07 09:00:02 localhost kernel: QLogic NetXtreme II iSCSI Driver bnx2i v2.7.10.1 (Jul 16, 2014)
Feb 07 09:00:02 localhost kernel: iscsi: registered transport (bnx2i)
Feb 07 09:00:02 localhost kernel: iscsi: registered transport (be2iscsi)
Feb 07 09:00:02 localhost kernel: In beiscsi_module_init, tt=000000009a087c1c
Feb 07 09:00:03 localhost systemd[1]: Finished dracut cmdline hook.
Feb 07 09:00:03 localhost systemd[1]: Starting dracut pre-udev hook...
Feb 07 09:00:03 localhost kernel: device-mapper: uevent: version 1.0.3
Feb 07 09:00:03 localhost kernel: device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
Feb 07 09:00:03 localhost kernel: RPC: Registered named UNIX socket transport module.
Feb 07 09:00:03 localhost kernel: RPC: Registered udp transport module.
Feb 07 09:00:03 localhost kernel: RPC: Registered tcp transport module.
Feb 07 09:00:03 localhost kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb 07 09:00:03 localhost dracut-pre-udev[429]: sh: /sbin/sysctl: No such file or directory
Feb 07 09:00:03 localhost dracut-pre-udev[428]: modprobe: ERROR: Error running install command '/sbin/modprobe --ignore-install sunr>
Feb 07 09:00:03 localhost dracut-pre-udev[428]: modprobe: ERROR: could not insert 'sunrpc': Invalid argument
Feb 07 09:00:03 localhost rpc.statd[445]: Version 2.1.1 starting
Feb 07 09:00:03 localhost rpc.statd[445]: Initializing NSM state
Feb 07 09:00:03 localhost rpc.statd[445]: Running as root. chown /var/lib/nfs to choose different user
Feb 07 09:00:04 localhost kernel: raid6: neonx8 gen() 1825 MB/s
Feb 07 09:00:04 localhost kernel: raid6: neonx8 xor() 1243 MB/s
Feb 07 09:00:04 localhost kernel: raid6: neonx4 gen() 1829 MB/s
Feb 07 09:00:04 localhost kernel: raid6: neonx4 xor() 1309 MB/s
Feb 07 09:00:04 localhost kernel: raid6: neonx2 gen() 1569 MB/s
Feb 07 09:00:05 localhost kernel: raid6: neonx2 xor() 1207 MB/s
Feb 07 09:00:05 localhost kernel: raid6: neonx1 gen() 1174 MB/s
Feb 07 09:00:05 localhost kernel: raid6: neonx1 xor() 943 MB/s
Feb 07 09:00:05 localhost kernel: raid6: int64x8 gen() 908 MB/s
Feb 07 09:00:05 localhost kernel: raid6: int64x8 xor() 528 MB/s
Feb 07 09:00:05 localhost kernel: raid6: int64x4 gen() 1087 MB/s
Feb 07 09:00:06 localhost kernel: raid6: int64x4 xor() 588 MB/s
Feb 07 09:00:06 localhost kernel: raid6: int64x2 gen() 962 MB/s
Feb 07 09:00:06 localhost kernel: raid6: int64x2 xor() 523 MB/s
Feb 07 09:00:06 localhost kernel: raid6: int64x1 gen() 733 MB/s
Feb 07 09:00:06 localhost kernel: raid6: int64x1 xor() 389 MB/s
Feb 07 09:00:06 localhost kernel: raid6: using algorithm neonx4 gen() 1829 MB/s
Feb 07 09:00:06 localhost kernel: raid6: .... xor() 1309 MB/s, rmw enabled
Feb 07 09:00:06 localhost kernel: raid6: using neon recovery algorithm
Feb 07 09:00:06 localhost kernel: xor: measuring software checksum speed
Feb 07 09:00:06 localhost kernel: 8regs : 2704 MB/sec
Feb 07 09:00:06 localhost kernel: 32regs : 3056 MB/sec
Feb 07 09:00:06 localhost kernel: arm64_neon : 2742 MB/sec
Feb 07 09:00:06 localhost kernel: xor: using function: 32regs (3056 MB/sec)
Feb 07 09:00:07 localhost kernel: Btrfs loaded, crc32c=crc32c-generic, assert=on, zoned=yes
Feb 07 09:00:07 localhost systemd[1]: Finished dracut pre-udev hook.
Feb 07 09:00:07 localhost systemd[1]: Starting Rule-based Manager for Device Events and Files...
Feb 07 09:00:07 localhost systemd-udevd[477]: Network interface NamePolicy= disabled by default.
Feb 07 09:00:07 localhost systemd[1]: Started Rule-based Manager for Device Events and Files.
Feb 07 09:00:07 localhost systemd[1]: Starting dracut pre-trigger hook...
Feb 07 09:00:07 localhost dracut-pre-trigger[482]: rd.md=0: removing MD RAID activation
Feb 07 09:00:07 localhost systemd[1]: Finished dracut pre-trigger hook.
Feb 07 09:00:07 localhost systemd[1]: Starting Coldplug All udev Devices...
Feb 07 09:00:08 localhost systemd-udevd[477]: Network interface NamePolicy= disabled by default.
Feb 07 09:00:08 localhost systemd[1]: Created slice Slice /system/modprobe.
Feb 07 09:00:08 localhost systemd[1]: Starting Load Kernel Module configfs...
Feb 07 09:00:08 localhost systemd[1]: Finished Coldplug All udev Devices.
Feb 07 09:00:08 localhost systemd[1]: modprobe@configfs.service: Deactivated successfully.
Feb 07 09:00:08 localhost systemd[1]: Finished Load Kernel Module configfs.
Feb 07 09:00:08 localhost kernel: usb_phy_generic phy: supply vcc not found, using dummy regulator
Feb 07 09:00:08 localhost kernel: usb_phy_generic phy: dummy supplies not allowed for exclusive requests
Feb 07 09:00:08 localhost kernel: brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
Feb 07 09:00:08 localhost kernel: brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
Feb 07 09:00:08 localhost kernel: brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
Feb 07 09:00:08 localhost kernel: brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
Feb 07 09:00:08 localhost kernel: bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
Feb 07 09:00:08 localhost kernel: brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
Feb 07 09:00:08 localhost kernel: brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
Feb 07 09:00:08 localhost kernel: libphy: bcmgenet MII bus: probed
Feb 07 09:00:08 localhost systemd[1]: Mounting Kernel Configuration File System...
Feb 07 09:00:08 localhost kernel: brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
Feb 07 09:00:08 localhost kernel: bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Feb 07 09:00:08 localhost kernel: brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
Feb 07 09:00:08 localhost kernel: sdhci: Secure Digital Host Controller Interface driver
Feb 07 09:00:08 localhost kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
Feb 07 09:00:08 localhost kernel: sdhci: Copyright(c) Pierre Ossman
Feb 07 09:00:08 localhost kernel: pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffff>
Feb 07 09:00:08 localhost kernel: pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
Feb 07 09:00:08 localhost kernel: pci 0000:00:00.0: PME# supported from D0 D3hot
Feb 07 09:00:08 localhost kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Feb 07 09:00:08 localhost kernel: pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
Feb 07 09:00:08 localhost kernel: pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
Feb 07 09:00:08 localhost kernel: pci 0000:01:00.0: PME# supported from D0 D3cold
Feb 07 09:00:08 localhost kernel: pci 0000:00:00.0: BAR 14: assigned [mem 0x600000000-0x6000fffff]
Feb 07 09:00:08 localhost kernel: pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
Feb 07 09:00:08 localhost kernel: pci 0000:00:00.0: PCI bridge to [bus 01]
Feb 07 09:00:08 localhost kernel: pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
Feb 07 09:00:08 localhost kernel: pcieport 0000:00:00.0: enabling device (0000 -> 0002)
Feb 07 09:00:08 localhost kernel: unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
Feb 07 09:00:08 localhost kernel: pcieport 0000:00:00.0: PME: Signaling with IRQ 65
