Hi, I try to activate WOL on my Rockstor server.
I could activate it in BIOS settings and also can activate it by using ethtool.
ethtool -s eth0 wol g
which sets Wake-on: from d (deactivated) to g (for wake on MagicPacket)
Unfortunately this is not set permanently and after reboot again d = deactivated.
As in Rockstor 4 build with SuSE Leap 15.2 NetworkManger is used to configure NIC, i’m searching where I can add the command /usr/sbin/ethtool -s eth0 wol g
Startscript or during shutown?
Does anybody already configured WOL in Rockstor 4 build?
best regards
Andreas
