Xeoma Does this work?
I have installed the Rockon but there is no launch button? I have tried accessing the ip:port but nothing there, what am I missing?
Hi @kysdaddy,
It looks like the Xeoma Rock-On is just the server process and not the UI as the UI on Linux requires an X-Server.
Well that’s a shame. I tried logging into it from the windows app, but it kept rejecting me or the password.
Oh well.
Thanks for the info.
Chas
Hi @kysdaddy,
You’ll need to set a password in the xeoma.conf which would reside in the config pool you used for Xeoma.
For example, my config pool was named XEOMA, so I had to set a password in /mnt2/XEOMA/xeoma.conf and then restart Xeoma.
Great, I will try that. What do you know about getting dropbox working?
After installed visit /var/logs/messages and look for a line similar to ā€˜DATETIME HOSTNAME journal: Please visit https://www.dropbox.com/cli_link_nonce?nonce=CODE to link this device.’
I don’t have a /Var/logs folder?
You should have a /var/logs folder, not a /Var/logs folder. Linux is case sensitive.
So it is a typo on the rockon help link? I’ll look in /var/log when I get back home
Thanks
No, there’s no typo. I just checked and it says ā€œ/var/logs/messagesā€, which is correct.
Ok I’m really confused then.
I have a /var/log folder not a /var/logs
I’ll double check when I get home
Sorry, my mistake /var/logs is a mistake, should be /var/log. You are correct.
I’ve submitted the following issue
https://github.com/rockstor/rockon-registry/issues/158
To get that typo corrected.
Thank you sir!
Chas
Xeoma is working but still playing with Dropbox
