Hi all,
I’ve just tried to install rockon Zoneminder 1.30.
I follow instruction to set the right option but on the last part it says
“On first start, open zoneminder settings, go to the paths tab and enter the following for PATH_ZMS: /zm/cgi-bin/nph-zms”
Now the problem is that zoneminder 1.30 do not have paths tab in webui.
I tryed to put “PATH_ZMS: /zm/cgi-bin/nph-zms” into file “/ZoneMinder/conf.d/01-system-paths.conf”
but nothig the IP camera do not work.
I’ve also noticed that “/zm/cgi-bin/nph-zms” do not exist
so I tried using existing path “/usr/local/libexec/zoneminder/cgi-bin/nph-zms”
Also in this case nothing is working.
Into Log I see a huge number of error:
Componet zmdc report several:
“Can’t find process with command of ‘zma -m 1’”
“‘zma -m 1’ exited abnormally, exit status 255”
Component web_php report several
“Failed linking skins/classic/views/js/console.js to skins_classic_views_js_console-classic-1558111393.js”
who can help to have zoneminder working?
thanks
Antonio
