Zypper timeout (minor issue)
I noticed this error in the log
[13/Jan/2026 09:01:36] ERROR [system.pkg_mgmt:575] Consider applying updates to reduce backlog: Command '['zypper', '--xmlout', 'list-updates']' timed out after 15 seconds
Zypper takes 28 seconds on my machine. Can I update the timeout to 30 or 45 seconds? I grep’d zypper in the python but got lost.
rockstor:~ # date; zypper refresh; date
Wed Jan 21 10:44:32 CST 2026
Repository ‘Leap_15_6_Updates’ is up to date.
Repository ‘Update repository of openSUSE Backports’ is up to date.
Looking for gpg keys in repository Update repository with updates from SUSE Linux Enterprise 15.
gpgkey=http://download.opensuse.org/update/leap/15.6/sle/repodata/repomd.xml.key
Retrieving repository ‘Update repository with updates from SUSE Linux Enterprise 15’ metadata …[done]
Building repository ‘Update repository with updates from SUSE Linux Enterprise 15’ cache …[done]
Repository ‘Leap_15_6’ is up to date.
Looking for gpg keys in repository aeneas_jaissle’s Home Project (15.6).
gpgkey=https://download.opensuse.org/repositories/home:/aeneas_jaissle/15.6/repodata/repomd.xml.key
Retrieving repository ‘aeneas_jaissle’s Home Project (15.6)’ metadata …[done]
Building repository ‘aeneas_jaissle’s Home Project (15.6)’ cache …[done]
Repository ‘home_rockstor’ is up to date.
Repository ‘home_rockstor_branches_Base_System’ is up to date.
Repository ‘repo-openh264’ is up to date.
All repositories have been refreshed.
Wed Jan 21 10:45:00 CST 2026
Yes, we actually had an issue with a partial resolution attached to it. Take a look at:
that will give you the point to change if you don’t want to wait for the next stable test release.
To be more concise, you can change the value here:
from 15 to 40 which would reflect the value the next release will go with. And then restart Rockstor.
I’ll change it - mostly because I am too lazy to manually run zypper refresh every week or two.
Thank you.
