Activation code(UKFzJuPFAO5i0CiAUxJaNg
activation code not working due to a reinstall. I combined two ssd in the same pool.
WebUI
File “/opt/rockstor/src/rockstor/storageadmin/views/update_subscription.py”, line 88, in post
stableo = self._toggle_repos(password=password)
File “/opt/rockstor/src/rockstor/storageadmin/views/update_subscription.py”, line 69, in _toggle_repos
raise Exception(e_msg)
Exception: Activation code(UKFzJuPFAO5i0CiAUxJaNg==) could not be authorized. Verify the code and try again. If the problem persists, contact support@rockstor.com
Hi @douglaslott,
please remove any reference to activation codes etc
Did you get a stable subscription ant tried to enable it?
If yes please try again, maybe it was just a failing connection
@suman
Mirko
Hi @douglaslott,
I had replied to your e-mail. Please reply there directly if you have any follow-up questions. Thank you!
