Activation code(...)
won’t register after subscription
purchased annual sub, received licence key & copied to relevant field but registration errors.
File “/opt/rockstor/src/rockstor/storageadmin/views/update_subscription.py”, line 86, in post
stableo = self._toggle_repos(password=password)
File “/opt/rockstor/src/rockstor/storageadmin/views/update_subscription.py”, line 66, in _toggle_repos
raise Exception(e_msg)
Exception: Activation code(…) could not be authorized. Verify the code and try again. If the problem persists, contact support@rockstor.com
@fudgee Welcome to the Rockstor community.
I just noticed this issue with Appman and your new order and have resolved it before reading this forum post.
Also take care with publishing your activation code and Appliance ID on this open (public) forum.
In short, if anyone else has this issue it’s best to email support.
The cause in this case was a prior grace period subscription held by yourself under a different email. All resolved now however so if you give the new activation code another go you should be good.
