New to Rockstor, so I probably have bungled something somewhere. Additionally, while I have many years of linux experience, I’ve never quite gotten NFS right… so the likely hood of buglement there is quite high.
I created an NFS export, but then realized that I needed no_root_squash
. At first I thought I needed to use advanced editing to get this, and it appeared that I could only do that while creating an export. So I deleted the export I had already made, and added one through advanced editing. But that didn’t show up under exports, which didn’t seem right, so I deleted that and went back to the regular creation screen. I then saw that the admin ip option sets no_root_squash
, so I tried re-making the share with that… only to get the error in the screenshot.
Any suggestions would be appreciated. Thanks!
I think these are the steps I took
- Create an NFS share using the normal screen
- Delete the share
- Create (or attempt to) the share via advanced editing
- Delete the share from the advanced editor
- Attempt to create the share using the “Add NFS Export” button
- Get the error message
- Delete all references to the IP using the system shell, directly editing /etc/exports
NoneType: None
(note, the whitespace and newlines was not a mistake; that was in the error message)
