My pool exists but failed to start Rockstar. I was not able to refresh the repos.
I didn’t make any system or application changes and drives are looking good.
When I tried to run Zypper update, this command is asking for a password. I don’t have a password and I use the same appliance and hardware, No changes. UUID is the same for the past two years.
RiversideNas:~ # zypper refresh
Repository ‘Kernel_stable_Backport’ is up to date.
Repository ‘Leap_15_4’ is up to date.
Repository ‘Leap_15_4_Updates’ is up to date.
Authentication required for ‘http://fbxxxxxxxxxxxxxxxxxxxxxxxxxx1@updates.rockstor.com:8999/rockstor-stable/leap/15.4?credentials=/etc/zypp/credentials.d/Rockstor-Stable&auth=basic’
User Name: fbxxxxxxxxxxxxxxxxxxxxxxx81
Password:
Problem retrieving files from ‘Rockstor-Stable’.
Login failed. (http://fbxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx1@updates.rockstor.com:8999/rockstor-stable/leap/15.4/repodata/repomd.xml?credentials=/etc/zypp/credentials.d/Rockstor-Stable&auth=basic): The requested URL returned error: 401
Please see the above error message for a hint.
Skipping repository ‘Rockstor-Stable’ because of the above error.
RiversideNas:~ # systemctl start rockstor
A dependency job for rockstor.service failed. See ‘journalctl -xe’ for details.
RiversideNas:~ # dmesg | tail -20
[ 3.619612] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 3.620019] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 3.620106] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 3.622010] iwlwifi 0000:00:14.3: base HW address: 08:6a:c5:1f:1e:db
[ 4.280974] RTL8226B_RTL8221B 2.5Gbps PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 4.471104] r8169 0000:03:00.0 eth0: Link is Down
[ 4.646505] Bluetooth: hci0: Waiting for firmware download to complete
[ 4.648077] Bluetooth: hci0: Firmware loaded in 1591432 usecs
[ 4.648120] Bluetooth: hci0: Waiting for device to boot
[ 4.663110] Bluetooth: hci0: Device booted in 14650 usecs
[ 4.663140] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[ 4.664180] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-19-0-4.ddc
[ 4.667122] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 4.668907] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
[ 4.669150] Bluetooth: hci0: Firmware revision 0.4 build 249 week 27 2023
[ 4.672138] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[ 4.956017] NET: Registered PF_PACKET protocol family
[ 5.230946] NFSD: Unable to initialize client recovery tracking! (-110)
[ 5.232092] NFSD: starting 90-second grace period (net f0000000)
[ 7.538590] r8169 0000:03:00.0 eth0: Link is Up - 1Gbps/Full - flow control off
Server connected to the internet.
RiversideNas:~ # ping -c 3 download.opensuse.org
PING download.opensuse.org (195.135.223.226) 56(84) bytes of data.
64 bytes from 195.135.223.226 (195.135.223.226): icmp_seq=1 ttl=50 time=112 ms
64 bytes from 195.135.223.226 (195.135.223.226): icmp_seq=2 ttl=50 time=111 ms
64 bytes from 195.135.223.226 (195.135.223.226): icmp_seq=3 ttl=50 time=111 ms
— download.opensuse.org ping statistics —
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 111.067/111.430/111.926/0.362 ms
I am not using the UI because it is not working. I get the following message when I attempt to login to the UI.
502 Bad Gateway
nginx/1.21.5
