[ROCKSTOR 5.0.3-0]
I’ve created a snapshot on the root pool like this:
btrfs subvolume snapshot /mnt2/ROOT /mnt2/ROOT/.backup
After reboot, rockstor shows this snapshot as a share.
I can delete it via UI, but after reboot bootstrap service can’t start.
- Create a snapshot on ROOT pool.
- Reboot
- Delete the share via interface
- Reboot
Rockstor.log during bootstrap load:
[05/Sep/2023 19:20:57] ERROR [storageadmin.middleware:34] Error running a command. cmd = /usr/sbin/btrfs property get /mnt2/ROOT/.backup ro. rc = 1. stdout = ['']. stderr = ['ERROR: failed to open /mnt2/ROOT/.backup: No such file or directory', 'ERROR: failed to detect object type: No such file or directory', '']
File "/opt/rockstor/.venv/lib/python3.6/site-packages/django/core/handlers/base.py", line 185, in _get_response
File "/opt/rockstor/.venv/lib/python3.6/site-packages/django/views/decorators/csrf.py", line 58, in wrapped_view
File "/opt/rockstor/.venv/lib/python3.6/site-packages/django/views/generic/base.py", line 68, in view
File "/opt/rockstor/.venv/lib/python3.6/site-packages/rest_framework/views.py", line 495, in dispatch
File "/opt/rockstor/.venv/lib/python3.6/site-packages/rest_framework/views.py", line 455, in handle_exception
self.raise_uncaught_exception(exc)
File "/opt/rockstor/.venv/lib/python3.6/site-packages/rest_framework/views.py", line 466, in raise_uncaught_exception
raise exc
File "/opt/rockstor/.venv/lib/python3.6/site-packages/rest_framework/views.py", line 492, in dispatch
File "/usr/lib64/python3.6/contextlib.py", line 52, in inner
return func(*args, **kwds)
File "/opt/rockstor/src/rockstor/storageadmin/views/command.py", line 395, in post
import_shares(p, request)
File "/opt/rockstor/src/rockstor/storageadmin/views/share_helpers.py", line 96, in import_shares
shares_in_pool = shares_info(pool)
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 1011, in shares_info
pool_mnt_pt, snap_idmap[vol_id]
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 1055, in parse_snap_details
writable = not get_property(full_snap_path, "ro")
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 2346, in get_property
o, e, rc = run_command(cmd)
File "/opt/rockstor/src/rockstor/system/osi.py", line 251, in run_command
system.exceptions.CommandException: Error running a command. cmd = /usr/sbin/btrfs property get /mnt2/ROOT/.backup ro. rc = 1. stdout = ['']. stderr = ['ERROR: failed to open /mnt2/ROOT/.backup: No such file or directory', 'ERROR: failed to detect object type: No such file or directory', '']
[05/Sep/2023 19:20:57] ERROR [smart_manager.data_collector:1015] Failed to update share state.. exception: ['Internal Server Error: Expecting value: line 1 column 1 (char 0)']
