Hi
What is the Rockstor teams response to this warning in the btrfs mailing list?
http://www.spinics.net/lists/linux-btrfs/msg56546.html
Has anybody seen this behavior?
Hi
This is scary
I think Rockstor should also include a big fat warning for now, that users really shouldnāt use raid5/6 with BTRFS.
This also scares me a little since my pool is RAID6.
I havent experienced problems though.
And my RAID6 did recover from a serious crash at the very start of my Rockstor experience, using the tools available at the time (I donāt remember the exact procedure I used, but it ended up with a scrub repairing the damage to the filesystem).
This is something that needs a thorough looking into by the people programming and maintaining BTRFS.
As I read the reply to the bug report, the error should be able to correct itself by running 2 scrubs in a row. But with the reduced scrubbing speed on RAID56, this would be a week long procedure on my pool.
I wanted to use Rockstor as a replacement for my Windows/hardware Raid setup i use today.
The features of btrfs is what i was looking for, but since i started with it in may i got the feeling it isnt quiet ready yet.
The other thing is that the status of btrfs is not communicated very well, i have use many, many hours to find answers.
Hope the Rockstor team is making a statement!
Well the only statement they can make is what theyāve allready said.
That RAID56 is still considered as in development/testing, and should be used with caution.
BTRFS development is completely separate from Rockstor, and I donāt think the developers listen much to what Rockstor has to say.
But off course Rockstor has to be clear about that using RAID56 still has its risks, and should only be used after carefull consideration.
@FREE_NORWAY Welcome to the Rockstor community. Yes there have been a number or concerns of the production readiness of btrfs raid 5/6 and also a number of discussions on this forum where a few participant have expressed a degree of satisfaction with these parity variants of btrfs; bar the performance issues with scrubbing of course which have been a long standing issue. And prior to the indicated thread the recent communications re raid 5/6 on the linux-btrfs mailing list were edging towards it being considered stable; this is evident in the changes that happened on the btrfs wiki entry on the 24th June as a result of that thread, in brief:
the subtraction of "...should be usable for most purposes..."
https://btrfs.wiki.kernel.org/index.php?title=RAID56&diff=next&oldid=29769
and the addition of:
āThe first two of these problems mean that the parity RAID code is not suitable for any system which might encounter unplanned shutdowns (power failure, kernel lock-up), and it should not be considered production-ready.ā
https://btrfs.wiki.kernel.org/index.php?title=RAID56&curid=5631&diff=30429&oldid=30425
and:
āIt is recommended that parity RAID be used āāāonlyāāā for testing purposes.ā
We also have the addition on the main page relating to Parity btrfs which relates to raid5/6 variants:
** Single and Dual Parity implementations (experimental, not production-ready)
with the bold bit added on the same day as the above changes.
https://btrfs.wiki.kernel.org/index.php?title=Main_Page&curid=1&diff=30427&oldid=30343
Iām afraid I dropped the ball on this one as I had these changes lined up ready to post in one of our ongoing forum threads on btrfs raid 5/6 but alas failed to do so in a timely manner by currently running a few days late. There are now a couple of issues open to address this within the docs and the Web-UI that I hope to make some progress on shortly.
Thanks for starting a newer and fresher thread more specifically on this recent issue and do please consider others experience and statements on these parity levels in the linked forum thread, and as @KarstenV kindly points out in this thread the general more cautious recommendation (ie for production) is to not use the btrfs parity variants of raid 5/6.
That thread has in turn been linked to from a number of other less focused threads.
As it goes the Rockstor docs did recently receive and merge and rapidly published a generous and very frank addition relating to bugs in btrfs raid 5/6 and their impact on the raid 5/6 recovery process by @Fantastitech via issue:
where a couple of known bugs in raid5/6 can hamper the recovery process.
It can be very disconcerting looking as closely as the developers do at the underlying technologies of many modern projects, given their complexity, and Rockstor is as all non trivial technologies are, dependant on very many projects doing the same with their technologies. It is also worth noting that even ext4 has regular bugs found but they are often very much corner cases, and this is what btrfs is definitely moving towards.
Thanks for the juggling prompt here; this thread should be updated with progress on the referenced issues.
Oh crap, is pretty much all I can say to that, as my install is running raid5
Edit: Although it will waste a load of space looks like I can change it raid1 given this new evidence relating to the stability of raid5 I think I will.
Makes me wonder if anything got corrupted when replacing a failing disk a month or so back (Although that disk was still working just had bad sectors)
Not surprised⦠BTRFS has itās bugs just like every other option out there! I primarily use Raid0 in my Rockstor NAS and backup important data every night to Backblaze B2 using HashBackup⦠I have a Raid5 array with some older disks and I canāt seem to kill itā¦
This doesnāt change my mind about Rockstor or BTRFS is anyway, I still trust my data to be as safe as possible on my Rockstor NAS⦠Iāve even been thinking about deploying a secondary Rockstor NAS to use the replication feature buuut Backblaze B2 @ $0.005/GB is still a better ROI.
Keep in mind Iām in Canada
Best $/GB Iāve ever gotten was 4TB HGST (I know it could be cheaper if I went with Seagate but I have sworn to never but another one of their drives again) was $0.0415/GB so at that rate itās ~8 months without accounting for power usage + other hardware costs⦠Of course this isnāt including the possibility of needing to recover which would be expensive but Iām optimistic and just preparing for the worst and hoping for the best! lol
Just a slightly belated update: as from Rockstor 3.8-14.03 testing channel updates, the associated text in the Web-UI by each raid selection point now includes a ā⦠raid5 and raid6 are not production-ready.ā: akin to the new status of these parity raid levels as per the btrfs wiki main page. The Official Rockstor docs already had warnings of raid5/6 maturity levels but these have been updated as well to be more in keeping with the official btrfs wiki wording. And the FAQ section also received some updates along these same lines. These changes were made against the GitHub issues I previously referenced in this thread.
Thanks to all concerned, including the btrfs developers and documentors, for bringing this matter to the fore.
btrfs got an official status page. Maybe it should be linked in the rockstor documents
@Yoshi Yes thatās a good idea. I did see this mentioned in linux-btrfs mailing list and though the same. But given itās only been up for a day or two lets give it time to settle and the general consensus to pan out; Iāve created an issue in our rockstor-doc repo so that it doesnāt get lost:
Do please consider tending to this one if you fancy, just make a note in the issue if you embark on it so that we donāt get avoidable overlapping effort.
Well spotted and thanks for bringing this up.
Some progress is being made: https://www.phoronix.com/scan.php?page=news_item&px=Btrfs-RAID5-RAID6-Fixed
Hopefully this will get merged into Linux 4.10
This fixes only a single issue where scrub could corrupt your corrupted FS even further by not locking whole strip⦠this does NOT fix any of other issues.
An please stop pasting this guys article in multiple threads because Iām starting to think you got some end in profits from advertising. If you care to show us some real progress on btrfs, quote mailing list OR btrfs wiki - other sources are considered a noise.
Again, btrfs RAID 5 & 6 profiles are considered at the moment: experimental / very unstable / very unpredictable. That profile can AND WILL eat your data in the long run, will leave you with errors that scrub is unable to recover from, will silently provide false recovery data fooling scrub into further corruption of FS.
Until in btrfs wiki it will be marked all green please donāt come here proclaiming some sort of victory based on some misinformed persons random article
This is the most ridiculous thing someone said about me ever⦠For advertising? Are you serious? Maybe you should read again what I said.
Phil asked me if I could keep an eye on the progress that is being made. And that is what Iāve done. I said SOME PROGRESS, nothing more, nothing less.
Reading and understanding is the keyā¦
@Tomasz_Kusmierz ???
Ok, having quotes from btrfs mailing list or wiki (wiki will probably get updated once these patches merged in Kernel, so by 4.10) probably could be better, on the other side not all Rockstor users have to be āIT guysā so an article explaining it is good.
Not considering btrfs mailing vs other blogs article, why did you react that way? ![]()
My reaction to last posts? āNice, thereās a patch partially fixing btrfs issues (like every patch on Rockstor against 200 open issues, not fixing all things, but fixing!) and our forum users take care of btrfs and Rockstor developmentā
Believe me Tom, that was a ālittleā unkind.
M.
Ok, My apologies to Yoshi. I did jumped up and down on your throat for little reason.
Anyway, in my defense Iām simply pissed of about current situation in community that somebody comes in and proclaim the āraid5 fixā ( the article actually states that āBtrfs RAID5/RAID6 Support Finally Get Fixedā ) and then there is a myriad of people coming back saying āI beg you please please save my non backed up data from raid 5ā and you want to punch in the face that douche that wrote āyeach itās fixedā. And the guy that wrote that article is doing it for advertisement, there are 5 advertisements spots around this misguiding article.
Sorry again Yoshi that Iāve put you in same bag with him. I shouldnāt.
@Flyer ⦠I know it was more than unkind
@Tomasz_Kusmierz
Letās forget it, no hard feelings here.
I can understand your point better now, maybe the article is more positive than it should be, but I think Phoronix.com isnāt the badest source for information like that.
Lets say btrfs raid5/6 is a liitle less flawed than before with this fix. But still far away from being stable in concerns of raid5/6.
Again, sorry for that mate. Iām rooting for raid6 big time, right now Iāve got 8 disks in personal array and due to raid10 I only get 4 disk capacity ⦠and letās face it I would like to get more. Also if 2 disks die, Iām colloquially f*** ā¦
Thanks for raising your concerns but working out your differences @Tomasz_Kusmierz and @Yoshi. Obviously, we are all in the same team here wishing for a stabler btrfs and a better Rockstor. While it can be frustrating, letās be respectful to the open source community as a whole and not forget that itās hard work and takes time, especially so with filesystem development.
Simplified version:
Donāt use RAID 5 / 6 BTRFS Modes! Use RAID 0,1 or 10
RAID is NOT Backup!
Free space in BTRFS is complicated
Compression issues.
RAID56 Status
The parity RAID code has multiple serious data-loss bugs in it. It should not be used for anything other than testing purposes. - https://btrfs.wiki.kernel.org/index.php/RAID56
Raid is not backup:
āRAID guards against one kind of hardware failure. Thereās lots of failure modes that it doesnāt guard against.
File corruption
Human error (deleting files by mistake)
Catastrophic damage (someone dumps water onto the server)
Viruses and other malware
Software bugs that wipe out data
Hardware problems that wipe out data or cause hardware damage (controller malfunctions, firmware bugs, voltage spikes, ā¦)
and more.ā - http://serverfault.com/questions/2888/why-is-raid-not-a-backup
How much free space do I have? or My filesystem is full, and Iāve put almost nothing into it!
Short story: you have data and metadata stored differently. If there is no space for one of them - your disk is full. If you need to rebalance, you need free disk space for both.
My personal suggestion:
from ~10% with pure SSD solution to ~20% of free storage space with HDDs, and something in between for mixed solution.
Long story:
https://btrfs.wiki.kernel.org/index.php/FAQ#How_much_free_space_do_I_have.3F
"Do your own benchmarks. LZO seems to give satisfying results for general use."
From personal experience:
