Hello,
here it is:
“CrashPlan”: {
“containers”: {
“Crashplan”: {
“image”: “gfjardim/crashplan”,
“launch_order”: 1,
“opts”: [
"–net=host",
“ports”: {
“4242”: {
“description”: “Crashplan Server Port. Suggested default: 4242.”,
“host_default”: 4242,
“label”: “Crashplan Server port”,
“protocol”: “tcp”
“4243”: {
“description”: “Crashplan Server Port. Suggested default: 4243.”,
“host_default”: 4243,
“protocol”: “tcp”
“4280”: {
“description”: “VNC HTTP Port. Suggested default: 4280.”,
“host_default”: 4280,
“label”: “Crashplan VNC HTTP Server port”,
“protocol”: “tcp”
"volumes": {
"/data": {
"description": "Select the Share containing your Backups; In case of black screen, check permissions",
"label": "Backups Share",
"min_size": 1073741824
"/config": {
"description": "Select the Share containing your Crashplan Configuration; In case of black screen, check permissions",
"label": "Chrashplan Configuration",
"description": "Crashplan Cloud Backup Server",
"ui": {
"https": true,
"slug": "web"
"volume_add_support": true,
"website": "http://crashplan.com",
"version": "1.0"
Untested though.
Usage:
- copy to /opt/rockstor/rockons-metastore/CrashplanDesktop.json
- Go to WebUI->RockOns --> Update
- Install Crashplan Rock-On
- I had to chmod 777 the shares
- Browse to http://rockstor:4280/vnc.html?host=rockstor&port=4280
Greetings,
Hendrik
