[ Hi
Been researching in and around Rockstor now for a couple of months, utilised an old PC (Celeron core duo on an ATX MOBO), waited for Black Friday deals (Ebay) and purchased 4X2Gb Ram, a Kingston A400 240 Gb SSD (OS), a couple of Seagate Ironwolf 4TB HDD (Data Store), plus some accessories from a local supplier.
Downloaded the generic ISO and utilising the recommended ISO builder (Rawrite 32 disc image tool) for a USB device installation which ran very neatly. (I had more problems changing the boot sequence in the BIOS being an absolute novice).
So, Rockstore is up and running with very little pain, not being used to anything outside of windows for a lot of years (Before windows 3.1) I stumbled at the change over from a monitor to a WEB UI, waiting for a screen to open, wondering what should happen next until I noticed a note re the web address to access the system. (Felt a bit daft at that moment).
Anyway, I am now setting things up whilst heat soaking the new (and old) kit (Is that still a term/process used?) and have got to the stage of setting up pools and shares.
From my interpretation of the docs a pool is usually a whole disc or set of discs
Quoting from the docs
“ Creating a Pool
Only whole disk drives can be used to create Pools
When reading about setting up rock-ons I find:
The Rock-ons root
All Rock-ons require the Rock-on service to be enabled and prior to enabling this service it must be configured. This is a simple matter of configuring a sufficiently large share for the rock-ons to be installed into. It is possible to use the existing ‘out of the box’ home share but this is not recommended.
The following shows a Recommended Minimum 5 GB rock-ons-root share backed by a previously created pool named*** *****rock-pool
I am finding this a little confusing, does this mean that the rock pool has to have a disc to itself with a pool set up named rock-pool?
If not ( I don’t think it actually does but clarification would be appreciated), can it reside in the OS disc (240GB should be sufficient capacity for such stuff), if so, would shares be needed for rock-on roots, rock-on configs/data, and the rock-ons themselves, say 20 GB each perhaps.
Thanks in advance
PS Its beginning to look a tremendous system and I’m looking forward to extending thoughts/desires possibly to a web browser and plex service for the family videos/snaps etc.]
[write here]
[paste here]
