Deleted pfsense static IP and server got an IP assigned by the DHCP:
10.10.10.131 00:15:17:dc:2c:5e Rockstor 2016/11/13 01:21:14 2016/11/13 03:21:14 online acti
[root@Rockstor ~]# ifconfig
enp2s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 94:de:80:ba:35:60 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp6s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.10.10.131 netmask 255.255.255.0 broadcast 10.10.10.255
inet6 fe80::215:17ff:fedc:2c5e prefixlen 64 scopeid 0x20
ether 00:15:17:dc:2c:5e txqueuelen 1000 (Ethernet)
RX packets 385 bytes 40571 (39.6 KiB)
TX packets 119 bytes 17870 (17.4 KiB)
device interrupt 18 memory 0xf7a20000-f7a40000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 109 bytes 46333 (45.2 KiB)
TX packets 109 bytes 46333 (45.2 KiB)
clli shows the old static IP: 10.10.10.18
added static ip mapping:
00:15:17:dc:2c:5e 10.10.10.18 Rockstor
and rebooted the server
cli shows old dynamic IP: 10.10.10.131
pfsense shows correct IP online
10.10.10.18 00:15:17:dc:2c:5e Rockstor n/a n/a online static
Interface has correct static IP
inet 10.10.10.18 netmask 255.255.255.0 broadcast 10.10.10.255
RX packets 227 bytes 25932 (25.3 KiB)
TX packets 116 bytes 17349 (16.9 KiB)
GUI accessible via static IP, but is not showing any IP under appliance IP
Any ideas?
