Deleting Shares
At a loss here. Trying to delete a share.
File “/opt/rockstor/eggs/gunicorn-19.7.1-py2.7.egg/gunicorn/workers/sync.py”, line 68, in run_for_one
self.accept(listener)
File “/opt/rockstor/eggs/gunicorn-19.7.1-py2.7.egg/gunicorn/workers/sync.py”, line 27, in accept
Seems multiple problems creping up.
Your guidance is always appreciated.
Rock On… hehe…
@dvanremortel Hello again.
This may be down to what has now, hopefully, been addressed in the stable channel as from 3.9.2-12 via:
What version of Rockstor are you seeing this on. I know you had both a stable and a testing install at one point?
If you follow the forum link in that issue it gives more info, and a work around, on what was found to occasionally block share (subvol) deletion. Linking to @Haioken and @Rene_Castberg 's thread here for convenience:
Hey, thank you for the reply.
Screenshot%20from%202018-03-15%2009-30-31
I have the lastest version of Rockstor, I removed the non-production edition I had running.
Simply put, I had TWO shares. File and Media. I was able to successfully remove the Files share without issue, when I tried to remove the Media share it gave me the error I shared.
I then tried to remove the POOL and that removed the pool and the share. So not sure what the issue was.
