Disk error trying to delete readonly file system
Trying to cleanup everything around a failed replication
[write here]
File “/opt/rockstor/src/rockstor/storageadmin/views/pool.py”, line 793, in delete
remove_share(so.pool, so.subvol_name, so.pqgroup, force=force)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 1185, in remove_share
toggle_path_rw(subvol_mnt_pt, rw=True)
File “/opt/rockstor/src/rockstor/system/osi.py”, line 545, in toggle_path_rw
return run_command([CHATTR, attr, path])
File “/opt/rockstor/src/rockstor/system/osi.py”, line 289, in run_command
system.exceptions.CommandException: Error running a command. cmd = /usr/bin/chattr -i /mnt2/Data-Raid/.snapshots/c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing/testing_21_replication_1. rc = 1. stdout = [‘’]. stderr = [‘/usr/bin/chattr: Read-only file system while setting flags on /mnt2/Data-Raid/.snapshots/c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing/testing_21_replication_1’, ‘’]
I believe you will have to change the snapshots you want to delete to read-write.
Vault2:/mnt2/Data-Raid/.snapshots # rm -d -R xxxxxx
rm: cannot remove ‘xxxxxx/testing_21_replication_1/1980/01/Green Light.gif’: Read-only file system
rm: cannot remove ‘xxxxxx/testing_21_replication_1/1980/01/Green Light.png’: Read-only file system
rm: cannot remove ‘xxxxxx/testing_21_replication_1/1980/01/Red Light blur.gif’: Read-only file system
rm: cannot remove ‘xxxxxx/testing_21_replication_1/1980/01/Red Light.gif’: Read-only file system
rm: cannot remove ‘xxxxxx/testing_21_replication_1/1980/01/Red Light.png’: Read-only file system
rm: cannot remove ‘xxxxxx/testing_21_replication_1/1980 - Copy/01/Green Light.gif’: Read-only file system
rm: cannot remove ‘xxxxxx/testing_21_replication_1/1980 - Copy/01/Green Light.png’: Read-only file system
rm: cannot remove ‘xxxxxx/testing_21_replication_1/1980 - Copy/01/Red Light blur.gif’: Read-only file system
rm: cannot remove ‘xxxxxx/testing_21_replication_1/1980 - Copy/01/Red Light.gif’: Read-only file system
rm: cannot remove ‘xxxxxx/testing_21_replication_1/1980 - Copy/01/Red Light.png’: Read-only file system
Vault2:/mnt2/Data-Raid/.snapshots # rm -d -R -f xxxxxx
Vault2:/mnt2/Data-Raid/.snapshots # rm -R -f xxxxxx
Vault2:/mnt2/Data-Raid/.snapshots # ls -AlF
total 0
drwxr-xr-x 1 root root 48 Sep 13 18:15 c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing/
drwxrwxrwx 1 root root 48 Sep 13 14:24 xxxxxx/
Vault2:/mnt2/Data-Raid/.snapshots # cd
Vault2:/mnt2/Data-Raid # ls -AlF
total 0
drwxr-xr-x 1 root root 100 Sep 13 18:15 .snapshots/
drwxr-xr-x 1 root root 0 Sep 13 18:15 c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing/
MOUNT CMD everything is rw
Vault2:/mnt2/Data-Raid # mount
/dev/sdf4 on / type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=258,subvol=/@/.snapshots/1/snapshot)
devtmpfs on /dev type devtmpfs (rw,nosuid,size=4096k,nr_inodes=1519496,mode=755,inode64)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
tmpfs on /run type tmpfs (rw,nosuid,nodev,size=2449704k,nr_inodes=819200,mode=755,inode64)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2803)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,nosuid,nodev,relatime,pagesize=2M)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
/dev/sdf4 on /.snapshots type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=257,subvol=/@/.snapshots)
/dev/sdf4 on /boot/grub2/i386-pc type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=266,subvol=/@/boot/grub2/i386-pc)
/dev/sdf4 on /home type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=259,subvol=/@/home)
/dev/sdf4 on /boot/grub2/x86_64-efi type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=267,subvol=/@/boot/grub2/x86_64-efi)
/dev/sdf4 on /opt type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=260,subvol=/@/opt)
/dev/sdf4 on /root type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=261,subvol=/@/root)
/dev/sdf4 on /srv type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=262,subvol=/@/srv)
/dev/sdf4 on /var type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=264,subvol=/@/var)
/dev/sdf4 on /tmp type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=263,subvol=/@/tmp)
/dev/sdf4 on /usr/local type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=265,subvol=/@/usr/local)
/dev/sdf2 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/sdc on /mnt2/Data-Raid type btrfs (rw,relatime,space_cache=v2,subvolid=5,subvol=/)
/dev/sda on /mnt2/Data-2 type btrfs (rw,relatime,space_cache=v2,subvolid=5,subvol=/)
/dev/sdd on /mnt2/Data-1 type btrfs (rw,relatime,space_cache=v2,subvolid=5,subvol=/)
/dev/sdf4 on /mnt2/ROCK-ONS/btrfs type btrfs (rw,noatime,ssd,discard=async,space_cache,subvolid=258,subvol=/@/.snapshots/1/snapshot)
tracefs on /sys/kernel/debug/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
/dev/sdc on /mnt2/c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing type btrfs (rw,relatime,space_cache=v2,subvolid=260,subvol=/c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing)
/dev/sdc on /mnt2/.snapshots/c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing/testing_25_replication_1 type btrfs (rw,relatime,space_cache=v2,subvolid=261,subvol=/.snapshots/c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing/testing_25_replication_1)
tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=1224852k,nr_inodes=306213,mode=700,inode64)
This is all happening because of replication failing and I still have not been able to fix that. It fails differently every time.
Did you use the btrfs property to make the snapshot read/write? For example:
btrfs property set -ts /path/to/snapshot ro false
No I did not. I’m a newbe and did not know about that. I rebuilt my system. Had 3 good replications of a test shat but none of them put any data in the recieving share. I them rebooted the receiving system and Now I’m getting the below error and it looks like the same problem cropped up.
[15/Sep/2024 14:08:04] INFO [storageadmin.views.snapshot:61] Supplanting share (c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing) with snapshot (.snapshots/c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing/testing_28_replication_1).
[15/Sep/2024 14:08:04] ERROR [storageadmin.util:44] Exception: Error running a command. cmd = /usr/sbin/btrfs property set /mnt2/Data-Raid/.snapshots/c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing/testing_28_replication_1 ro false. rc = 1. stdout = [‘’]. stderr = [‘ERROR: cannot flip ro->rw with received_uuid set, use force if you really want that’, ‘’]
File “/opt/rockstor/src/rockstor/storageadmin/views/clone_helpers.py”, line 94, in create_repclone
set_property(snap_path, “ro”, “false”, mount=False)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 2314, in set_property
return run_command(cmd)
system.exceptions.CommandException: Error running a command. cmd = /usr/sbin/btrfs property set /mnt2/Data-Raid/.snapshots/c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing/testing_28_replication_1 ro false. rc = 1. stdout = [‘’]. stderr = [‘ERROR: cannot flip ro->rw with received_uuid set, use force if you really want that’, ‘’]
[15/Sep/2024 14:08:04] ERROR [smart_manager.replication.receiver:100] b’Failed to promote the oldest Snapshot to Share.‘. Exception: 500 Server Error: Internal Server Error for url: http://127.0.0.1:8000/api/shares/6/snapshots/testing_28_replication_1/repclone
[15/Sep/2024 14:11:04] ERROR [smart_manager.replication.receiver:100] b’Failed to promote the oldest Snapshot to Share.’. Exception: Share matching query does not exist.
[15/Sep/2024 14:13:03] ERROR [smart_manager.replication.receiver:100] b’Failed to promote the oldest Snapshot to Share.'. Exception: Share matching query does not exist.
Tried
Vault2:/mnt2/Data-Raid/.snapshots # btrfs property set -ts /mnt2/Data-Raid/.snapshots ro false
ERROR: Could not get subvolume flags: Invalid argument
Vault2:/mnt2/Data-Raid/.snapshots # btrfs property set -ts /mnt2/Data-Raid/.snapshots/c0450590-f2b9-de11-8a1b-90e6ba7a072b_testing ro false
