Disk id (122) does not exist.
SSDs with mixed filesystems are causing unsupported and not found errors.
Pre-Used SSDs with partitions with fat and BTRFS used.
Bootup is from USB Stick,
Traceback (most recent call last): File "/opt/rockstor/src/rockstor/storageadmin/views/disk_smart.py", line 56, in _validate_disk return Disk.objects.get(id=did) ^^^^^^^^^^^^^^^^^^^^^^^^ File "/opt/rockstor/.venv/lib/python3.11/site-packages/django/db/models/manager.py", line 87, in manager_method return getattr(self.get_queryset(), name)(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/opt/rockstor/.venv/lib/python3.11/site-packages/django/db/models/query.py", line 637, in get raise self.model.DoesNotExist( storageadmin.models.disk.Disk.DoesNotExist: Disk matching query does not exist.
So you installed Rockstor on a USB stick and boot it from there. But then you also have:
How many SSDs, which models and capacities?
How are they partitioned? MBR/GPT? Order and sizes?
What filesystem on which partition?
I can see some of that from the screenshots provided, but is that all there is? Or are there disks, partitions or filesystems Rockstor didn’t detect.
@h0ysala welcome to the Rockstor community.
Additionally, in the documentation it is recommended to wipe the disks before re-using them for Rockstor, especially if they have various partitions set up (similar to @tachikoma’s questions). See also
https://rockstor.com/docs/installation/pre-install-howto.html#wiping-disks
How are the SSDs connected to the Rockstor instance? If using certain enclosures that don’t provide a unique serial ID per drive, Rockstor will not recognize them correctly, as it relies heavily on the unique identifiers. You can find a few posts on this forum of such scenarios.
