System is telling me that the drive is busy even though I have just restarted the machine and there is nothing that should be using the drives.
I just tried to create a pool with the two hard disks that are available.
File “/opt/rockstor/src/rockstor/storageadmin/views/pool.py”, line 444, in post
add_pool(p, dnames)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 116, in add_pool
out, err, rc = run_command(cmd, log=True)
File “/opt/rockstor/src/rockstor/system/osi.py”, line 201, in run_command
CommandException: Error running a command. cmd = /usr/sbin/mkfs.btrfs -f -d raid1 -m raid1 -L pool1 /dev/disk/by-id/ata-ST91000640NS_9XG0706E /dev/disk/by-id/ata-ST91000640NS_9XG07KDG. rc = 1. stdout = ['btrfs-progs v4.19.1 ', ‘See http://btrfs.wiki.kernel.org for more information.’, ‘’, ‘’]. stderr = [‘ERROR: unable to open /dev/disk/by-id/ata-ST91000640NS_9XG0706E: Device or resource busy’, ‘’]
[paste here]
