I have a RAID10 pool (called Data) with a failed disk. I found Data Loss-prevention and Recovery in Rockstor — Rockstor documentation and following the steps under “Data loss Prevention and Recovery in RAID10 Pools”. Unfortunately, it looks like the BTRFS replace command failed. In addition, after running this command a second disk now shows as detached.
Steps I performed
I followed each step shown on the documentation page posted above:
btrfs fi showoriginally showed “warning, device 1 is missing”- The devices listed under
Label: 'Data'are: /dev/sdc, /dev/sdd, and /dev/sde
mount -o degraded /dev/sdc /mnt2/Data-
lsblk -P -o 'NAME,MODEL,SERIAL,SIZE,TRAN,VENDOR,HCTL,TYPE,FSTYPE,LABEL,UUID'- Used this to verify that the new drive is /dev/sda by matching model and serial #.
- Found this command in the discussion at: Problems with disk replacement - #2 by phillxnet
btrfs replace start 1 /dev/sda /mnt2/Data- Note: It seems there may be an error in the documentation as it specifies an old drive as the target. This did not make sense to me, and I received an error until I specified my new drive (/dev/sda) as the target.
btrfs replace status /mnt2/Data- This showed 0% for a moment, then eventually showed cancelled.
btrfs fi shownow shows device 1 and 2 are missing. Also, it showsbytenr mismatch, want=21069824, have=0andCouldn't read chunk treewhich I don’t recall from the first time.
Any help is appreciated. Thanks.
