phemmy22
(Femi Bankole)
January 21, 2024, 11:31pm
1
I was having write protection error and most of my disk that was previously used with Truenas.
I did not want to troubleshoot the disk in Rockstor. So I prepare the removal but deleting the share, deleted a pool and remove the associated disk.
I checked the disk in my window server and there was no write-protection on any of the disk.
I inserted the disk back to Rockstor.And now it does not recognised the disk or any other disk.
I tried a reboot and disk rescan.
Every time I rescan I get the error bellow.
Deleted a pool and remove the associated disk.
Now it does not recognised the disk or any other disk.
File "/opt/rockstor/src/rockstor/storageadmin/views/disk.py", line 520, in post
File "/opt/rockstor/.venv/lib/python2.7/site-packages/django/utils/decorators.py", line 185, in inner
return func(*args, **kwargs)
File "/opt/rockstor/src/rockstor/storageadmin/views/disk.py", line 375, in _update_disk_state
p_info = dev_pool_info[dev_name]
KeyError: '/dev/sdat'
phillxnet
(Philip Guyton)
January 22, 2024, 8:49am
2
@phemmy22 Hello there, and welcome to the Rockstor community forum.
Could you give us the version of Rockstor you are experiencing this with. It does look like it is not longer able to interpret what it is seeing from the output of the following command:
lsblk -P -o NAME,MODEL,SERIAL,SIZE,TRAN,VENDOR,HCTL,TYPE,FSTYPE,LABEL,UUID
or one very similar.
if you could past the output of that command, run as the root user, we may be able to see, or reproduce the issue. This may lead what has gone wrong with this systems ability to read the drive state.
A copy of the output of thefollowing command would also be useful to diagnose this issue:
ls -la /dev/disk/by-id/
As a result the install is not able to update it’s knowledge (the Web-UI) of what disks are attached.
Let us know the version of this install, and any details of how it was installed that you may have. We have not changed that code for a while now, but you may be running a really old instance and this may help with identifying your options.
phemmy22
(Femi Bankole)
January 22, 2024, 10:54am
3
Many thanks for the reply.
Output of command- was:
ROCK-01:~ # ls -la /dev/disk/by-id/
total 0
drwxr-xr-x 2 root root 3860 Jan 22 00:07 .
drwxr-xr-x 8 root root 160 Jan 21 23:15 ..
lrwxrwxrwx 1 root root 9 Jan 21 23:15 ata-PLDS_DVD-ROM_DS-8D3SH_202290313341 -> ../../sr0
lrwxrwxrwx 1 root root 10 Jan 21 23:15 ata-WDC_WD82PURZ-85TEUY0_VGKUSU2G -> ../../sdap
lrwxrwxrwx 1 root root 11 Jan 21 23:15 ata-WDC_WD82PURZ-85TEUY0_VGKUSU2G-part1 -> ../../sdap1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 ata-WDC_WD82PURZ-85TEUY0_VGKUSU2G-part2 -> ../../sdap2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 ata-WDC_WD82PURZ-85TEUY0_VGKUYW2G -> ../../sdaq
lrwxrwxrwx 1 root root 11 Jan 21 23:15 ata-WDC_WD82PURZ-85TEUY0_VGKUYW2G-part1 -> ../../sdaq1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 ata-WDC_WD82PURZ-85TEUY0_VGKUYW2G-part2 -> ../../sdaq2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 ata-WDC_WD82PURZ-85TEUY0_VGKUZ38G -> ../../sdar
lrwxrwxrwx 1 root root 10 Jan 21 23:15 ata-WDC_WD82PURZ-85TEUY0_VGKV545G -> ../../sdao
lrwxrwxrwx 1 root root 11 Jan 21 23:15 ata-WDC_WD82PURZ-85TEUY0_VGKV545G-part1 -> ../../sdao1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 ata-WDC_WD82PURZ-85TEUY0_VGKV545G-part2 -> ../../sdao2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 ata-WDC_WD82PURZ-85TEUY0_VGKV9R5G -> ../../sdas
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000039848236af4 -> ../../sdai
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-3500003984823a4d4 -> ../../sdt
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984823ac1c -> ../../sdaj
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984823bc34 -> ../../sdaa
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984823c608 -> ../../sdak
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-3500003984823c9ac -> ../../sdu
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984823c9ec -> ../../sdab
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-3500003984823d418 -> ../../sdv
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-3500003984823d518 -> ../../sdz
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984823deb8 -> ../../sdag
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984823e030 -> ../../sdal
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-3500003984823fe50 -> ../../sdw
lrwxrwxrwx 1 root root 10 Jan 22 00:07 scsi-35000039848280218 -> ../../sdac
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000039848280b68 -> ../../sdy
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000039848280b68-part1 -> ../../sdy1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000039848280b68-part2 -> ../../sdy2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-350000398482822e8 -> ../../sdan
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-350000398482822e8-part1 -> ../../sdan1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-350000398482822e8-part2 -> ../../sdan2
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000039848283970 -> ../../sdr
lrwxrwxrwx 1 root root 10 Jan 22 00:06 scsi-35000039848288794 -> ../../sdae
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000039848288ad8 -> ../../sdah
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-35000039848288ad8-part1 -> ../../sdah1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-35000039848288ad8-part2 -> ../../sdah2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000039848289828 -> ../../sdad
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-35000039848289828-part1 -> ../../sdad1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-35000039848289828-part2 -> ../../sdad2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000039848289844 -> ../../sdam
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-35000039848289844-part1 -> ../../sdam1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-35000039848289844-part2 -> ../../sdam2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984828a500 -> ../../sdaf
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-3500003984828a500-part1 -> ../../sdaf1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-3500003984828a500-part2 -> ../../sdaf2
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-3500003984828a568 -> ../../sdq
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984828a568-part1 -> ../../sdq1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984828a568-part2 -> ../../sdq2
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-3500003984828ac20 -> ../../sdx
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984828ac20-part1 -> ../../sdx1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984828ac20-part2 -> ../../sdx2
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-3500003984828bac4 -> ../../sds
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984828bac4-part1 -> ../../sds1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500003984828bac4-part2 -> ../../sds2
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca01bddaa70 -> ../../sdd
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca01bddaa70-part1 -> ../../sdd1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca01ca80cf8 -> ../../sdc
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca01ca80cf8-part1 -> ../../sdc1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca01cb78d18 -> ../../sdb
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca01cb78d18-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e22c01c -> ../../sdg
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca25e22c01c-part1 -> ../../sdg1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e22db88 -> ../../sdf
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca25e22db88-part1 -> ../../sdf1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e2351c0 -> ../../sdo
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e235204 -> ../../sdm
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e23c418 -> ../../sdj
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca25e23c418-part1 -> ../../sdj1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e23d0cc -> ../../sde
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca25e23d0cc-part1 -> ../../sde1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e23fbc0 -> ../../sdp
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca25e23fbc0-part1 -> ../../sdp1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e244844 -> ../../sdl
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca25e244844-part1 -> ../../sdl1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e245bf4 -> ../../sdh
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca25e245bf4-part1 -> ../../sdh1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e246170 -> ../../sdk
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca25e246170-part1 -> ../../sdk1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e24bd18 -> ../../sdi
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca25e24bd18-part1 -> ../../sdi1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-35000cca25e24e7cc -> ../../sdn
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca25e24e7cc-part1 -> ../../sdn1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-35000cca25e24e7cc-part2 -> ../../sdn2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500605ba00e968b4 -> ../../sdav
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-3500605ba00e968b4-part1 -> ../../sdav1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500605ba00e968c0 -> ../../sdau
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-3500605ba00e968c0-part1 -> ../../sdau1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500605ba00e968cc -> ../../sdat
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-3500605ba00e968cc-part1 -> ../../sdat1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-3500605ba00e9c5d8 -> ../../sdaw
lrwxrwxrwx 1 root root 11 Jan 21 23:15 scsi-3500605ba00e9c5d8-part1 -> ../../sdaw1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 scsi-36a4badb013824b0029a42568175a7a44 -> ../../sda
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-36a4badb013824b0029a42568175a7a44-part1 -> ../../sd
a1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-36a4badb013824b0029a42568175a7a44-part2 -> ../../sd
a2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-36a4badb013824b0029a42568175a7a44-part3 -> ../../sd
a3
lrwxrwxrwx 1 root root 10 Jan 21 23:15 scsi-36a4badb013824b0029a42568175a7a44-part4 -> ../../sd
a4
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000039848236af4 -> ../../sdai
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x500003984823a4d4 -> ../../sdt
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984823ac1c -> ../../sdaj
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984823bc34 -> ../../sdaa
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984823c608 -> ../../sdak
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x500003984823c9ac -> ../../sdu
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984823c9ec -> ../../sdab
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x500003984823d418 -> ../../sdv
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x500003984823d518 -> ../../sdz
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984823deb8 -> ../../sdag
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984823e030 -> ../../sdal
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x500003984823fe50 -> ../../sdw
lrwxrwxrwx 1 root root 10 Jan 22 00:07 wwn-0x5000039848280218 -> ../../sdac
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000039848280b68 -> ../../sdy
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000039848280b68-part1 -> ../../sdy1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000039848280b68-part2 -> ../../sdy2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x50000398482822e8 -> ../../sdan
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x50000398482822e8-part1 -> ../../sdan1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x50000398482822e8-part2 -> ../../sdan2
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000039848283970 -> ../../sdr
lrwxrwxrwx 1 root root 10 Jan 22 00:06 wwn-0x5000039848288794 -> ../../sdae
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000039848288ad8 -> ../../sdah
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000039848288ad8-part1 -> ../../sdah1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000039848288ad8-part2 -> ../../sdah2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000039848289828 -> ../../sdad
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000039848289828-part1 -> ../../sdad1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000039848289828-part2 -> ../../sdad2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000039848289844 -> ../../sdam
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000039848289844-part1 -> ../../sdam1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000039848289844-part2 -> ../../sdam2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984828a500 -> ../../sdaf
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x500003984828a500-part1 -> ../../sdaf1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x500003984828a500-part2 -> ../../sdaf2
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x500003984828a568 -> ../../sdq
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984828a568-part1 -> ../../sdq1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984828a568-part2 -> ../../sdq2
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x500003984828ac20 -> ../../sdx
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984828ac20-part1 -> ../../sdx1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984828ac20-part2 -> ../../sdx2
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x500003984828bac4 -> ../../sds
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984828bac4-part1 -> ../../sds1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500003984828bac4-part2 -> ../../sds2
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca01bddaa70 -> ../../sdd
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca01bddaa70-part1 -> ../../sdd1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca01ca80cf8 -> ../../sdc
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca01ca80cf8-part1 -> ../../sdc1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca01cb78d18 -> ../../sdb
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca01cb78d18-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca0bef5fd2a -> ../../sdap
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000cca0bef5fd2a-part1 -> ../../sdap1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000cca0bef5fd2a-part2 -> ../../sdap2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca0bef613ee -> ../../sdaq
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000cca0bef613ee-part1 -> ../../sdaq1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000cca0bef613ee-part2 -> ../../sdaq2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca0bef614cd -> ../../sdar
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca0bef62b6f -> ../../sdao
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000cca0bef62b6f-part1 -> ../../sdao1
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x5000cca0bef62b6f-part2 -> ../../sdao2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca0bef63ca1 -> ../../sdas
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e22c01c -> ../../sdg
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca25e22c01c-part1 -> ../../sdg1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e22db88 -> ../../sdf
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca25e22db88-part1 -> ../../sdf1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e2351c0 -> ../../sdo
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e235204 -> ../../sdm
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e23c418 -> ../../sdj
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca25e23c418-part1 -> ../../sdj1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e23d0cc -> ../../sde
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca25e23d0cc-part1 -> ../../sde1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e23fbc0 -> ../../sdp
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca25e23fbc0-part1 -> ../../sdp1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e244844 -> ../../sdl
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca25e244844-part1 -> ../../sdl1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e245bf4 -> ../../sdh
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca25e245bf4-part1 -> ../../sdh1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e246170 -> ../../sdk
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca25e246170-part1 -> ../../sdk1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e24bd18 -> ../../sdi
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca25e24bd18-part1 -> ../../sdi1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x5000cca25e24e7cc -> ../../sdn
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca25e24e7cc-part1 -> ../../sdn1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x5000cca25e24e7cc-part2 -> ../../sdn2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500605ba00e968b4 -> ../../sdav
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x500605ba00e968b4-part1 -> ../../sdav1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500605ba00e968c0 -> ../../sdau
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x500605ba00e968c0-part1 -> ../../sdau1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500605ba00e968cc -> ../../sdat
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x500605ba00e968cc-part1 -> ../../sdat1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x500605ba00e9c5d8 -> ../../sdaw
lrwxrwxrwx 1 root root 11 Jan 21 23:15 wwn-0x500605ba00e9c5d8-part1 -> ../../sdaw1
lrwxrwxrwx 1 root root 9 Jan 21 23:15 wwn-0x6a4badb013824b0029a42568175a7a44 -> ../../sda
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x6a4badb013824b0029a42568175a7a44-part1 -> ../../sd
a1
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x6a4badb013824b0029a42568175a7a44-part2 -> ../../sd
a2
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x6a4badb013824b0029a42568175a7a44-part3 -> ../../sd
a3
lrwxrwxrwx 1 root root 10 Jan 21 23:15 wwn-0x6a4badb013824b0029a42568175a7a44-part4 -> ../../sd
a4
Installed version: ROCKSTOR 4.5.8-0
It was installed through a USB drive.
Installed on Dell R710 with SAS controller in IT Mode
Drives are from Truenas core ZFS file destroyed/formatted.
phillxnet
(Philip Guyton)
January 22, 2024, 12:18pm
4
@phemmy22 Thanks for the command output and addition info.
I’ve edited the post format wise. Could you also post the output from the following command:
lsblk -P -p -o NAME,MODEL,SERIAL,SIZE,TRAN,VENDOR,HCTL,TYPE,FSTYPE,LABEL,UUID
Thanks.
You have a lot of drives there, nice.
phemmy22
(Femi Bankole)
January 22, 2024, 1:29pm
5
OUTPUT:
ROCK-01:~ # lsblk -P -p -o NAME,MODEL,SERIAL,SIZE,TRAN,VENDOR,HCTL,TYPE,FSTYPE,LABEL,UUID
NAME="/dev/sda" MODEL="PERC H700" SERIAL="00447a5a176825a429004b8213b0ad4b" SIZE="237.9G" TRAN="" VENDOR="DELL " HCTL="2:2:0:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sda1" MODEL="" SERIAL="" SIZE="2M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sda2" MODEL="" SERIAL="" SIZE="64M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="vfat" LABEL="EFI" UUID="79A7-4640"
NAME="/dev/sda3" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="swap" LABEL="SWAP" UUID="7eaf7b5f-d2db-48a1-9ac1-fef1f6ad6373"
NAME="/dev/sda4" MODEL="" SERIAL="" SIZE="235.8G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="btrfs" LABEL="ROOT" UUID="ae33ccad-e775-4ca3-b1bc-07c0e993e1e7"
NAME="/dev/sdb" MODEL="HUS72302CLAR2000" SERIAL="YGK7YASK" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:0:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdb1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdc" MODEL="HUS72302CLAR2000" SERIAL="YGJZE2HK" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:1:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdc1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdd" MODEL="HUS72302CLAR2000" SERIAL="YFKXX4YK" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:2:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdd1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sde" MODEL="HUS72602CLAR2000" SERIAL="K5GMPM4A" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:3:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sde1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdf" MODEL="HUS72602CLAR2000" SERIAL="K5GM58TA" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:4:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdf1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdg" MODEL="HUS72602CLAR2000" SERIAL="K5GM3G5A" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:5:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdg1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdh" MODEL="HUS72602CLAR2000" SERIAL="K5GMZWEA" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:6:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdh1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdi" MODEL="HUS72602CLAR2000" SERIAL="K5GN6AZA" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:7:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdi1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdj" MODEL="HUS72602CLAR2000" SERIAL="K5GMNSXA" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:8:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdj1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdk" MODEL="HUS72602CLAR2000" SERIAL="K5GN07SA" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:9:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdk1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdl" MODEL="HUS72602CLAR2000" SERIAL="K5GMYKTA" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:10:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdl1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdm" MODEL="HUS72602CLAR2000" SERIAL="K5GME5DA" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:11:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdn" MODEL="HUS72602CLAR2000" SERIAL="K5GN964A" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:12:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdn1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdn2" MODEL="" SERIAL="" SIZE="1.8T" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="ntfs" LABEL="New Volume" UUID="D08E56538E5631E8"
NAME="/dev/sdo" MODEL="HUS72602CLAR2000" SERIAL="K5GME4VA" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:13:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdp" MODEL="HUS72602CLAR2000" SERIAL="K5GMTGUA" SIZE="1.8T" TRAN="sas" VENDOR="HITACHI " HCTL="5:0:14:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdp1" MODEL="" SERIAL="" SIZE="128M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sr0" MODEL="PLDS DVD-ROM DS-8D3SH" SERIAL="202290313341" SIZE="1024M" TRAN="ata" VENDOR="PLDS " HCTL="6:0:0:0" TYPE="rom" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdq" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A2NRFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:17:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdq1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdq2" MODEL="" SERIAL="" SIZE="556.8G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="EMC-02" UUID="3214736933042245341"
NAME="/dev/sdr" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A28JFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:18:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sds" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A2S6FBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:19:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sds1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sds2" MODEL="" SERIAL="" SIZE="556.8G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="EMC-02" UUID="3214736933042245341"
NAME="/dev/sdt" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A0VMFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:20:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdu" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A1E2FBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:21:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdv" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A1J0FBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:22:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdw" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A1VTFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:23:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdx" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A2R2FBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:24:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdx1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdx2" MODEL="" SERIAL="" SIZE="556.8G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="EMC-02" UUID="3214736933042245341"
NAME="/dev/sdy" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A20VFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:25:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdy1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdy2" MODEL="" SERIAL="" SIZE="556.8G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="EMC-02" UUID="3214736933042245341"
NAME="/dev/sdz" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A1JVFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:26:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdaa" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A16FFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:27:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdab" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A1E9FBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:28:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdac" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A1WLFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:29:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdad" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A2LLFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:30:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdad1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdad2" MODEL="" SERIAL="" SIZE="556.8G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="EMC-02" UUID="3214736933042245341"
NAME="/dev/sdae" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A2FCFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:31:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdaf" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A2NDFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:32:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdaf1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdaf2" MODEL="" SERIAL="" SIZE="556.8G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="EMC-02" UUID="3214736933042245341"
NAME="/dev/sdag" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A1PYFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:33:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdah" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A2H7FBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:34:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdah1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdah2" MODEL="" SERIAL="" SIZE="556.8G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="EMC-02" UUID="3214736933042245341"
NAME="/dev/sdai" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A038FBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:35:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdaj" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A0ZRFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:36:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdak" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A1BGFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:37:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdal" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A1QPFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:38:0" TYPE="disk" FSTYPE="zfs_member" LABEL="" UUID=""
NAME="/dev/sdam" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A2LQFBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:39:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdam1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdam2" MODEL="" SERIAL="" SIZE="556.8G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="EMC-02" UUID="3214736933042245341"
NAME="/dev/sdan" MODEL="AL13SXB6 CLAR600" SERIAL="Y7F0A262FBMB" SIZE="558.8G" TRAN="sas" VENDOR="TOSHIBA " HCTL="5:0:40:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdan1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdan2" MODEL="" SERIAL="" SIZE="556.8G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="EMC-02" UUID="3214736933042245341"
NAME="/dev/sdao" MODEL="WDC WD82PURZ-85TEUY0" SERIAL="VGKV545G" SIZE="7.3T" TRAN="sas" VENDOR="ATA " HCTL="5:0:42:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdao1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdao2" MODEL="" SERIAL="" SIZE="7.3T" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="NET-05" UUID="6743294917121295681"
NAME="/dev/sdap" MODEL="WDC WD82PURZ-85TEUY0" SERIAL="VGKUSU2G" SIZE="7.3T" TRAN="sas" VENDOR="ATA " HCTL="5:0:43:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdap1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdap2" MODEL="" SERIAL="" SIZE="7.3T" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="NET-05" UUID="6743294917121295681"
NAME="/dev/sdaq" MODEL="WDC WD82PURZ-85TEUY0" SERIAL="VGKUYW2G" SIZE="7.3T" TRAN="sas" VENDOR="ATA " HCTL="5:0:44:0" TYPE="disk" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdaq1" MODEL="" SERIAL="" SIZE="2G" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdaq2" MODEL="" SERIAL="" SIZE="7.3T" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="zfs_member" LABEL="NET-05" UUID="6743294917121295681"
NAME="/dev/sdar" MODEL="WDC WD82PURZ-85TEUY0" SERIAL="VGKUZ38G" SIZE="7.3T" TRAN="sas" VENDOR="ATA " HCTL="5:0:45:0" TYPE="disk" FSTYPE="btrfs" LABEL="02_08TB" UUID="0eb0a88d-b331-48cf-9dd4
-bbe06c0b336f"
NAME="/dev/sdas" MODEL="WDC WD82PURZ-85TEUY0" SERIAL="VGKV9R5G" SIZE="7.3T" TRAN="sas" VENDOR="ATA " HCTL="5:0:46:0" TYPE="disk" FSTYPE="btrfs" LABEL="02_08TB" UUID="0eb0a88d-b331-48cf-9dd4
-bbe06c0b336f"
NAME="/dev/sdat" MODEL="M0004-1ZC101 SM" SERIAL="ZA2DEW8W" SIZE="9.1T" TRAN="sas" VENDOR="ST10000D" HCTL="5:0:47:0" TYPE="disk" FSTYPE="btrfs" LABEL="01_10TB" UUID="aefdc423-9c3e-430a-b3ef-8c75
c277e89c"
NAME="/dev/sdat1" MODEL="" SERIAL="" SIZE="16M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdau" MODEL="M0004-1ZC101 SM" SERIAL="ZA2DPMMK" SIZE="9.1T" TRAN="sas" VENDOR="ST10000D" HCTL="5:0:48:0" TYPE="disk" FSTYPE="btrfs" LABEL="01_10TB" UUID="aefdc423-9c3e-430a-b3ef-8c75
c277e89c"
NAME="/dev/sdau1" MODEL="" SERIAL="" SIZE="16M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdav" MODEL="M0004-1ZC101 SM" SERIAL="ZA2DX4BW" SIZE="9.1T" TRAN="sas" VENDOR="ST10000D" HCTL="5:0:49:0" TYPE="disk" FSTYPE="btrfs" LABEL="01_10TB" UUID="aefdc423-9c3e-430a-b3ef-8c75
c277e89c"
NAME="/dev/sdav1" MODEL="" SERIAL="" SIZE="16M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
NAME="/dev/sdaw" MODEL="M0004-1ZC101 SM" SERIAL="ZA2DGLVS" SIZE="9.1T" TRAN="sas" VENDOR="ST10000D" HCTL="5:0:50:0" TYPE="disk" FSTYPE="btrfs" LABEL="01_10TB" UUID="aefdc423-9c3e-430a-b3ef-8c75
c277e89c"
NAME="/dev/sdaw1" MODEL="" SERIAL="" SIZE="16M" TRAN="" VENDOR="" HCTL="" TYPE="part" FSTYPE="" LABEL="" UUID=""
Thanks
Yes, I have a few drives.
phemmy22
(Femi Bankole)
January 23, 2024, 12:31pm
6
Hi There,
I updated using the “test update” version (I recently purchased the support version but can’t activate the licence key I received. I am waiting for the Appman support reply), and now I am unable to access the Rockstor homepage on my network.
Also, right from the initial installation, I noticed Rockstor does not load correctly if I have my diskshelf plugged in. I have to remove the cable from the controller before booting and then plug it back in after Rockstor loads its configuration. Is that behaviour normal because I have over 50 disks?
phillxnet
(Philip Guyton)
January 23, 2024, 8:08pm
7
I am basically email support (as project maintainer), and responded to your last email regarding a miss-match of entered and actual Appliance ID. The Email as sent: Monday, 22 January 2024 12:28 AM.
We have had successful interactions thus far on support so to let me know if you got that email.
Testing channel (non-production) is currently non-functional as of 5.0.6-0 and is not for regular/production use. And we do not do upgrade testing. Only fresh install testing. But we do strive to do stable to stable rpm testing, and have maintained this for the last few years on the openSUSE base. And before hand for a few years on our prior CentOS base.
Testing is not for you currently. We have changed almost everything under-the-hood: but it looks basically the same. If you do want to contribute to the testing channel by way ‘testing’ then fantastic, but it will not currently update from a prior install of any other Rockstor install. It must start from a fresh non-existent /opt/rockstor, (and no legay poetry instance) and a --force reinstall post having done the hard-reset procedure detailed in our contributors section: Contributing to Rockstor - Overview — Rockstor documentation
The testing channel is our way of ensuring each stable release does basically what it is supposed to do, given our limitations at the time: resources mainly. And our current testing phase is focusing on completely modernising our Python underlying back-end. This is the current Milestone:
And here is our doc section, linked to in our Web-UI, that explains our update channels:
https://rockstor.com/docs/interface/system/update_channels.html
To restore function go the Stable reinstall route, but your 50 disks are welcome in testing, and we do have an open issue re many disk systems to address in that Milestone. But testing is not for actual use: more development towards a usable stable release.
Hope that helps. At least for context. And check you spam or the like for that email. I expect we have just had an overlap here though.
phemmy22
(Femi Bankole)
January 23, 2024, 9:23pm
8
Many thanks, Philip.
I just realised some messages went straight to my bin, thanks to Yahoo mail
I will start with a fresh install and then license it for production.
Regards,
Femi
phillxnet
(Philip Guyton)
January 24, 2024, 9:19am
9
@phemmy22 Thanks for letting me know, much appreciated.
Yes, we, and others, have had issues re Yahoo mail, yet as of yesterday (and a few years proceeding this) our fastmail backed support email scores 10/10 when examined by: https://www.mail-tester.com/ : funny that.
Thanks again for supporting the project that way, by the way. Note also that it’s not a license, more a subscription service for sustainability purposes . The distributed rockstor package is licensed: FSF Free/Libre & OSI approved :
GPL-3.0-or-later AND (MIT AND Apache-2.0 AND GPL-3.0-or-later AND LGPL-3.0-or-later AND ISC)
As indicated here: Software update — Rockstor documentation
And as we are now entering the Stable Release Candidate phase in testing we have begun addressing update issues from the last stable rpm release of 4.6.1-0 to what-ever the next Stable will end up being: penciled in as 5.1.0-0. Not there yet however and 5.0.6-0 has some ongoing update issues, one of which was resolved yesterday and another today hopefully. I’m then hoping to get 5.0.7-0 out for more field tests.
It would also be super useful, when I get around to working on the pending drive identification issue outstanding in the current Milestone, if I could get more output from your install, if need be. This may help to resolve outstanding/future issues in the next stable release. We did once have a 27 disk set issue which we now have a regression test for:
def test_scan_disks_27_plus_disks_regression_issue(self):
Suspected minimum disk set to trigger /dev/sda /dev/sda[a-z] serial bug
when base root disk is /dev/sda ('/' on sda3):
first listed sda[a-z] dev (sdab in below) gets serial = None
second and subsequent listed sda[a-z] devs get serial = 'fake-serial-'
Note also that in addition to the above;
model, transport, vendor, and hctl
info are lost or inherited from sda for all sda[a-z] devices.
All are also labeled incorrectly as
root=True:
the root cause of this bug, see issue #1925.
N.B. an element of the trigger data is FSTYPE="btrfs" on the sda[a-z]
devices: without this the issue does not present.
And another related to a 36 disk set, again now with a test:
So in time it would be good to add your systems command outputs so that we have further real-world test data to ensure/prove our code is doing what its supposed to do.
Hope that helps, at least for some context.
phemmy22
(Femi Bankole)
January 27, 2024, 8:47pm
10
Hi Phil,
Sorry for the late reply.
Thank you for the clarification above.
I am happy to help with tests in my environment whenever needed.
I have reinstalled the package and updated it to ROCKSTOR 4.6.1-0.
But adding the disk in bits while writing to it.
When I checked the shelves, I might have a little to 100 disks in my environment.
I use the disks for Chia Farm, so the data don’t change. Though I lost 75% of the data while moving from Truenas, I am already rewriting it.
You are welcome with any test.
Thank you!
Femi
