A good chunk of the rockstor.log
return func(*args, **kwargs)
File "/opt/rockstor/src/rockstor/storageadmin/views/command.py", line 318, in post
import_shares(p, request)
File "/opt/rockstor/src/rockstor/storageadmin/views/share_helpers.py", line 83, in import_shares
volume_usage(pool, share.qgroup, share.pqgroup)
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 789, in volume_usage
out, err, rc = run_command(cmd, log=True)
CommandException: Error running a command. cmd = /sbin/btrfs qgroup show /mnt2/MD1220-DAS/MD1220. rc = 1. stdout = ['']. stderr = ["ERROR: can't list qgroups: quotas not enabled", '']
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sda3', model='PERC H710', serial='6848f690e936450018b7c3a11330997b', size=277558067, transport=None, vendor='DELL', hctl='0:2:0:0', type='part', fstype='btrfs', label='rockstor_rockstor', uuid='7f7acdd7-493e-4bb5-b801-b7b7dc289535', parted=True, root=True, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdt', model='HUC101212CSS600', serial='5000cca01d2af91c', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:6:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdu', model='HUC101212CSS600', serial='5000cca01d273a24', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:7:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdv', model='HUC101212CSS600', serial='5000cca01d21893c', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:8:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdw', model='ST91000640SS', serial='5000c500630450a3', size=976748544, transport='sas', vendor='SEAGATE', hctl='1:0:9:0', type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdp', model='HUC101212CSS600', serial='5000cca01d21885c', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:2:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdq', model='HUC101212CSS600', serial='5000cca01d29f384', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:3:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdr', model='HUC101212CSS600', serial='5000cca01d2188e0', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:4:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sds', model='HUC101212CSS600', serial='5000cca01d217968', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:5:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdx', model='ST91000640SS', serial='5000c50063044387', size=976748544, transport='sas', vendor='SEAGATE', hctl='1:0:10:0', type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdy', model='HUC101212CSS600', serial='5000cca01d2766c0', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:11:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdz', model='ST91000640SS', serial='5000c5006304544b', size=976748544, transport='sas', vendor='SEAGATE', hctl='1:0:12:0', type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdd', model='PERC H710', serial='6848f690e9364500219f33b21773ea22', size=585524838, transport=None, vendor='DELL', hctl='0:2:3:0', type='disk', fstype='btrfs', label='Test', uuid='612f1fc2-dfa8-4940-a1ad-e11c893b32ca', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sde', model='PERC H710', serial='6848f690e9364500219f33bb17fe7d7b', size=585524838, transport=None, vendor='DELL', hctl='0:2:4:0', type='disk', fstype='btrfs', label='Test', uuid='612f1fc2-dfa8-4940-a1ad-e11c893b32ca', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdf', model='PERC H710', serial='6848f690e936450021a4585b05e46fcc', size=7838315315, transport=None, vendor='DELL', hctl='0:2:5:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdg', model='PERC H710', serial='6848f690e936450021ed61830ae57fbf', size=7838315315, transport=None, vendor='DELL', hctl='0:2:6:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdb', model='PERC H710', serial='6848f690e9364500219f339b1610b547', size=585524838, transport=None, vendor='DELL', hctl='0:2:1:0', type='disk', fstype='btrfs', label='Test', uuid='612f1fc2-dfa8-4940-a1ad-e11c893b32ca', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdc', model='PERC H710', serial='6848f690e936450021ed614a077c1b44', size=7838315315, transport=None, vendor='DELL', hctl='0:2:2:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdl', model='PERC H710', serial='6848f690e936450021a4525005828671', size=4939212390, transport=None, vendor='DELL', hctl='0:2:11:0', type='disk', fstype='btrfs', label='5TBWDGREEN', uuid='a37956a8-a175-4906-82c1-bf843132da1a', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdm', model='PERC H710', serial='6848f690e936450021acd1f30663b877', size=7838315315, transport=None, vendor='DELL', hctl='0:2:12:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdn', model='HUC101212CSS600', serial='5000cca01d2144ac', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:0:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdo', model='HUC101212CSS600', serial='5000cca01d21bc10', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:1:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdh', model='PERC H710', serial='6848f690e9364500219f33d919c7488a', size=585524838, transport=None, vendor='DELL', hctl='0:2:7:0', type='disk', fstype='btrfs', label='Test', uuid='612f1fc2-dfa8-4940-a1ad-e11c893b32ca', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdi', model='PERC H710', serial='6848f690e936450021a4586906bd9742', size=7838315315, transport=None, vendor='DELL', hctl='0:2:8:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdj', model='PERC H710', serial='6848f690e936450021a45f9904046a2f', size=2899102924, transport=None, vendor='DELL', hctl='0:2:9:0', type='disk', fstype='btrfs', label='VMWARE_MECH_ARRAY', uuid='e6d13c0b-825f-4b43-81b6-7eb2b791b1c3', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdk', model='PERC H710', serial='6848f690e936450021acd1e705b389c6', size=7838315315, transport=None, vendor='DELL', hctl='0:2:10:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdaf', model='PERC H710', serial='fake-serial-77b9c3f8-7a3d-4add-9873-15c73ed56e27', size=976748544, transport=None, vendor='DELL', hctl='0:2:0:0', type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdag', model=None, serial='fake-serial-6fb0fd15-da47-4224-9ca9-d66bb64058e4', size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdad', model='PERC H710', serial='fake-serial-92ed2454-1246-40ec-8566-1a7dcc6076c5', size=234461593, transport=None, vendor='DELL', hctl='0:2:0:0', type='disk', fstype='btrfs', label='INTEL_SSD', uuid='a504bf03-0299-4648-8a95-c91aba291de8', parted=False, root=True, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdae', model=None, serial='fake-serial-ccae1c93-3df4-49e9-bc71-7c5e63849f85', size=234461593, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='INTEL_SSD', uuid='a504bf03-0299-4648-8a95-c91aba291de8', parted=False, root=True, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdab', model=None, serial=None, size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdac', model=None, serial='fake-serial-fc039240-4525-4786-bf72-66509c35ea29', size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdaa', model=None, serial='fake-serial-988a17dd-fd58-4c74-9284-1594887c31db', size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdaj', model=None, serial='fake-serial-dc53a2e1-84b0-445d-8f7e-1fc4dee8c343', size=234461593, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='INTEL_SSD', uuid='a504bf03-0299-4648-8a95-c91aba291de8', parted=False, root=True, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdah', model=None, serial='fake-serial-112c6bf6-d999-417a-bd95-0102742856e4', size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:20:55] DEBUG [system.osi:478] disks item = Disk(name='sdai', model=None, serial='fake-serial-a9ab6c94-c75b-4d90-b11d-ddff7f67dc66', size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:20:56] ERROR [storageadmin.util:44] exception: expected string or buffer
File "/opt/rockstor/src/rockstor/storageadmin/views/disk.py", line 377, in post
File "/opt/rockstor/src/rockstor/storageadmin/views/disk.py", line 342, in _update_disk_state
if (re.match('fake-serial-', do.serial) is not None) or (
File "/usr/lib64/python2.7/re.py", line 137, in match
return _compile(pattern, flags).match(string)
[14/May/2018 13:20:56] DEBUG [storageadmin.util:45] Current Rockstor version: 3.9.1-0
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sda3', model='PERC H710', serial='6848f690e936450018b7c3a11330997b', size=277558067, transport=None, vendor='DELL', hctl='0:2:0:0', type='part', fstype='btrfs', label='rockstor_rockstor', uuid='7f7acdd7-493e-4bb5-b801-b7b7dc289535', parted=True, root=True, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdt', model='HUC101212CSS600', serial='5000cca01d2af91c', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:6:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdu', model='HUC101212CSS600', serial='5000cca01d273a24', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:7:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdv', model='HUC101212CSS600', serial='5000cca01d21893c', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:8:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdw', model='ST91000640SS', serial='5000c500630450a3', size=976748544, transport='sas', vendor='SEAGATE', hctl='1:0:9:0', type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdp', model='HUC101212CSS600', serial='5000cca01d21885c', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:2:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdq', model='HUC101212CSS600', serial='5000cca01d29f384', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:3:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdr', model='HUC101212CSS600', serial='5000cca01d2188e0', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:4:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sds', model='HUC101212CSS600', serial='5000cca01d217968', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:5:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdx', model='ST91000640SS', serial='5000c50063044387', size=976748544, transport='sas', vendor='SEAGATE', hctl='1:0:10:0', type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdy', model='HUC101212CSS600', serial='5000cca01d2766c0', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:11:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdz', model='ST91000640SS', serial='5000c5006304544b', size=976748544, transport='sas', vendor='SEAGATE', hctl='1:0:12:0', type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdd', model='PERC H710', serial='6848f690e9364500219f33b21773ea22', size=585524838, transport=None, vendor='DELL', hctl='0:2:3:0', type='disk', fstype='btrfs', label='Test', uuid='612f1fc2-dfa8-4940-a1ad-e11c893b32ca', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sde', model='PERC H710', serial='6848f690e9364500219f33bb17fe7d7b', size=585524838, transport=None, vendor='DELL', hctl='0:2:4:0', type='disk', fstype='btrfs', label='Test', uuid='612f1fc2-dfa8-4940-a1ad-e11c893b32ca', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdf', model='PERC H710', serial='6848f690e936450021a4585b05e46fcc', size=7838315315, transport=None, vendor='DELL', hctl='0:2:5:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdg', model='PERC H710', serial='6848f690e936450021ed61830ae57fbf', size=7838315315, transport=None, vendor='DELL', hctl='0:2:6:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdb', model='PERC H710', serial='6848f690e9364500219f339b1610b547', size=585524838, transport=None, vendor='DELL', hctl='0:2:1:0', type='disk', fstype='btrfs', label='Test', uuid='612f1fc2-dfa8-4940-a1ad-e11c893b32ca', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdc', model='PERC H710', serial='6848f690e936450021ed614a077c1b44', size=7838315315, transport=None, vendor='DELL', hctl='0:2:2:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdl', model='PERC H710', serial='6848f690e936450021a4525005828671', size=4939212390, transport=None, vendor='DELL', hctl='0:2:11:0', type='disk', fstype='btrfs', label='5TBWDGREEN', uuid='a37956a8-a175-4906-82c1-bf843132da1a', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdm', model='PERC H710', serial='6848f690e936450021acd1f30663b877', size=7838315315, transport=None, vendor='DELL', hctl='0:2:12:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdn', model='HUC101212CSS600', serial='5000cca01d2144ac', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:0:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdo', model='HUC101212CSS600', serial='5000cca01d21bc10', size=1181116006, transport='sas', vendor='HGST', hctl='1:0:1:0', type='disk', fstype='btrfs', label='MD1220-DAS', uuid='12d76eb6-7aad-46ba-863e-d9c51e8e6f2d', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdh', model='PERC H710', serial='6848f690e9364500219f33d919c7488a', size=585524838, transport=None, vendor='DELL', hctl='0:2:7:0', type='disk', fstype='btrfs', label='Test', uuid='612f1fc2-dfa8-4940-a1ad-e11c893b32ca', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdi', model='PERC H710', serial='6848f690e936450021a4586906bd9742', size=7838315315, transport=None, vendor='DELL', hctl='0:2:8:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdj', model='PERC H710', serial='6848f690e936450021a45f9904046a2f', size=2899102924, transport=None, vendor='DELL', hctl='0:2:9:0', type='disk', fstype='btrfs', label='VMWARE_MECH_ARRAY', uuid='e6d13c0b-825f-4b43-81b6-7eb2b791b1c3', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdk', model='PERC H710', serial='6848f690e936450021acd1e705b389c6', size=7838315315, transport=None, vendor='DELL', hctl='0:2:10:0', type='disk', fstype='btrfs', label='BIGDATA', uuid='cb15142f-9d1e-4cb2-9b1f-adda3af6555f', parted=False, root=False, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdaf', model='PERC H710', serial='fake-serial-0b606a7b-c7fa-4cf0-9e7a-c8dcc70d4034', size=976748544, transport=None, vendor='DELL', hctl='0:2:0:0', type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdag', model=None, serial='fake-serial-2a01338a-d494-40ef-80d9-ba2888bfde5f', size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdad', model='PERC H710', serial='fake-serial-84d6ede5-091d-452b-8ebd-ced7625184aa', size=234461593, transport=None, vendor='DELL', hctl='0:2:0:0', type='disk', fstype='btrfs', label='INTEL_SSD', uuid='a504bf03-0299-4648-8a95-c91aba291de8', parted=False, root=True, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdae', model=None, serial='fake-serial-288f98c5-e108-4ca4-b1e0-fd4a791e7ea5', size=234461593, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='INTEL_SSD', uuid='a504bf03-0299-4648-8a95-c91aba291de8', parted=False, root=True, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdab', model=None, serial=None, size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdac', model=None, serial='fake-serial-09b57d88-eac0-42b6-b676-5eccd8f78535', size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdaa', model=None, serial='fake-serial-23a3af4d-3c6f-4b9c-a9b2-47f22a0b3c9e', size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdaj', model=None, serial='fake-serial-a8d06f68-fa9f-4e87-93dd-7ed785c5bdb2', size=234461593, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='INTEL_SSD', uuid='a504bf03-0299-4648-8a95-c91aba291de8', parted=False, root=True, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdah', model=None, serial='fake-serial-a7564264-de05-4bce-9d0c-54d480590936', size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:21:21] DEBUG [system.osi:478] disks item = Disk(name='sdai', model=None, serial='fake-serial-d6464bda-6974-4ef9-982e-15dfd87f4e39', size=976748544, transport=None, vendor=None, hctl=None, type='disk', fstype='btrfs', label='SCRATCH', uuid='a90e6787-1c45-46d6-a2ba-41017a17c1d5', parted=False, root=True, partitions={})
[14/May/2018 13:21:22] ERROR [storageadmin.util:44] exception: expected string or buffer
[14/May/2018 13:21:22] DEBUG [storageadmin.util:45] Current Rockstor version: 3.9.1-0
[14/May/2018 13:21:24] ERROR [system.osi:113] non-zero code(1) returned by command: ['/sbin/btrfs', 'qgroup', 'show', '/mnt2/MD1220-DAS/MD1220']. output: [''] error: ["ERROR: can't list qgroups: quotas not enabled", '']
[14/May/2018 13:21:24] ERROR [storageadmin.middleware:32] Exception occured while processing a request. Path: /api/commands/refresh-share-state method: POST
[14/May/2018 13:21:24] ERROR [storageadmin.middleware:33] Error running a command. cmd = /sbin/btrfs qgroup show /mnt2/MD1220-DAS/MD1220. rc = 1. stdout = ['']. stderr = ["ERROR: can't list qgroups: quotas not enabled", '']
