(Please note - if there is a not a means to recover the array, I can reinstall Rockstor and start over; I’m not prod yet. However, If this isn’t recoverable, then I’m hesitant to proceed with btrfs.)
A drive in a RAID1 array is failing (or rather, the file system has an error). From /var/log/messages:
Apr 14 16:18:50 rockstor kernel: BTRFS info (device sda): use lzo compression
Apr 14 16:18:50 rockstor kernel: BTRFS info (device sda): disk space caching is enabled
Apr 14 16:18:50 rockstor kernel: BTRFS info (device sda): has skinny extents
Apr 14 16:18:50 rockstor kernel: BTRFS error (device sda): failed to read chunk tree: -5
Apr 14 16:18:50 rockstor kernel: BTRFS error (device sda): open_ctree failed
Apr 14 16:19:51 rockstor kernel: BTRFS info (device sda): use lzo compression
Apr 14 16:19:51 rockstor kernel: BTRFS info (device sda): disk space caching is enabled
Apr 14 16:19:51 rockstor kernel: BTRFS info (device sda): has skinny extents
Apr 14 16:19:51 rockstor kernel: BTRFS error (device sda): failed to read chunk tree: -5
Apr 14 16:19:51 rockstor kernel: BTRFS error (device sda): open_ctree failed
etc. ad nauseum.
The pool is unmounted. I can click the pool in the UI but ‘Resize’ is not an option (I hoped to go there to remove it from the array).
This morning, I rebooted to try installing Rockstor 4. I noted that /dev/sda was not listed as a potential install target (that’s OK in that I did not intend to install to it anyway). On seeing an error, I booted back to Rockstor 3 and this is the current state.
File "/opt/rockstor/src/rockstor/storageadmin/views/pool_balance.py", line 47, in get_queryset
self._balance_status(pool)
return func(*args, **kwargs)
File "/opt/rockstor/src/rockstor/storageadmin/views/pool_balance.py", line 72, in _balance_status
cur_status = balance_status(pool)
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 1064, in balance_status
mnt_pt = mount_root(pool)
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 253, in mount_root
run_command(mnt_cmd)
CommandException: Error running a command. cmd = /bin/mount /dev/disk/by-label/TestPool /mnt2/TestPool -o ,compress=lzo. rc = 32. stdout = ['']. stderr = ['mount: wrong fs type, bad option, bad superblock on /dev/sda,', ' missing codepage or helper program, or other error', '', ' In some cases useful info is found in syslog - try', ' dmesg | tail or so.', '']
