Hi, I’ve just installed Rockstor on my self-build NAS (MSI J1800I Mini-ITX + 2xWD Green 1TB + SAMSUNG 32GB mSATA SSD). After first run, when it asks for hostname and admin credentials, i’ve seen first bug:
File “/opt/rockstor/src/rockstor/storageadmin/views/disk.py”, line 320, in post
return func(*args, **kwargs)
File “/opt/rockstor/src/rockstor/storageadmin/views/disk.py”, line 268, in _update_disk_state
dob.save()
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py”, line 734, in save
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py”, line 762, in save_base
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py”, line 846, in _save_table
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py”, line 885, in _do_insert
using=using, raw=raw)
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/manager.py”, line 127, in manager_method
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py”, line 920, in _insert
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/compiler.py”, line 974, in execute_sql
cursor.execute(sql, params)
DataError: value too long for type character varying(256)
But settings saved and it gone after page refresh. So I go further and… it seems Rockstor do not see any drives. Storage -> Disks is empty and clicking “Rescan” gives me this:
dob.save()
Upgrade to newest testing version does not any difference.
