Emby Rockon Update issue
Hi everyone. I’m trying to update my emby rockon and everytime I do, I keep getting the following trace error:
File “/opt/rockstor/src/rockstor/storageadmin/views/rockon.py”, line 106, in post
return func(*args, **kwargs)
File “/opt/rockstor/src/rockstor/storageadmin/views/rockon.py”, line 185, in _create_update_meta
File “/opt/rockstor/src/rockstor/storageadmin/util.py”, line 46, in handle_exception
raise RockStorAPIException(detail=e_msg, trace=traceback.format_exc())
RockStorAPIException: [‘Duplicate container(embyserver) definition detected. It belongs to another Rock-on(EmbyServer). Uninstall one of them and try again.’, ‘Traceback (most recent call last):\n File “/opt/rockstor/eggs/gunicorn-0.16.1-py2.7.egg/gunicorn/workers/sync.py”, line 34, in run\n client, addr = self.socket.accept()\n File “/usr/lib64/python2.7/socket.py”, line 202, in accept\n sock, addr = self._sock.accept()\nerror: [Errno 11] Resource temporarily unavailable\n’]
Any suggestions? Thank you in advance!
Hi @scarybaby, and welcome to the community!
The error you are seeing is related to a change in the name of the rock-on we had a little while ago (my doing), but all you need to do is to uninstall and re-install the rock-on. This is actually the recommended way (if not the only one) to update most docker images (on which rock-ons are based).
You will find more details, explanations, and most importantly instructions on how to do so in the post below:
Hope this helps!
