Hi
My scheduled scrub job has not completed for the last few runs. It terminates with Error 24 Too many open files. Likewise, I occasionally get the same error message when logging in to the web UI. Rebooting fixes the logon problem, but the problem returns after some (up)time.
I installed and ran lsof as recommended in in another topic, I could not make much sense of the output… I did however notice many lines like these for gunicorn and other packages:
gunicorn 10307 10324 root 45u REG 0,44 617 36999 /tmp/tmpD7CCS4 (deleted)
gunicorn 10307 10324 root 46u REG 0,44 617 37027 /tmp/tmpH1Dc_X (deleted)
gunicorn 10307 10324 root 47u REG 0,44 617 38196 /tmp/tmp075mXa (deleted)
gunicorn 10307 10324 root 48u REG 0,44 617 39250 /tmp/tmpsA75Ls (deleted)
gunicorn 10307 10324 root 49u REG 0,44 617 37275 /tmp/tmp7troCJ (deleted)
gunicorn 10307 10324 root 50u REG 0,44 617 38232 /tmp/tmpicczIw (deleted)
gunicorn 10307 10324 root 51u REG 0,44 617 37320 /tmp/tmp_wENgF (deleted)
gunicorn 10307 10324 root 52u REG 0,44 617 39530 /tmp/tmpS3eHXD (deleted)
The /tmp directory is currently empty
The log för the scheduled scrub job:
2 June 12th 2017, 1:42:00 am June 12th 2017, 1:42:03 am finished
3 June 19th 2017, 1:42:00 am June 19th 2017, 1:42:02 am finished
4 June 26th 2017, 1:42:00 am June 26th 2017, 1:42:02 am finished
5 July 3rd 2017, 1:42:00 am July 3rd 2017, 1:42:03 am finished
6 July 10th 2017, 1:42:00 am July 10th 2017, 1:42:02 am error
7 July 17th 2017, 1:42:00 am July 17th 2017, 1:42:02 am finished
8 July 24th 2017, 1:42:00 am July 24th 2017, 1:42:02 am error
9 July 31st 2017, 1:42:00 am July 31st 2017, 1:42:02 am error
10 August 7th 2017, 1:42:00 am August 7th 2017, 1:42:02 am error
11 August 14th 2017, 1:42:00 am August 14th 2017, 1:42:02 am error
Truncated Rockstor log file below (there are lots of similar errors in the file):
[13/Aug/2017 20:37:52] ERROR [storageadmin.views.command:84] Exception while refreshing state for Pool(pool-1). Moving on: Exception while running command([’/sbin/btrfs’, ‘fi’, ‘show’, ‘/dev/disk/by-id/ata-ST3000DM001-1ER166_W500QT0K’]): [Errno 24] Too many open files
[13/Aug/2017 20:37:52] ERROR [storageadmin.views.command:85] Exception while running command([’/sbin/btrfs’, ‘fi’, ‘show’, ‘/dev/disk/by-id/ata-ST3000DM001-1ER166_W500QT0K’]): [Errno 24] Too many open files
File “/opt/rockstor/src/rockstor/storageadmin/views/command.py”, line 76, in _refresh_pool_state
pool_info = get_pool_info(first_attached_dev.target_name)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 100, in get_pool_info
o, e, rc = run_command(cmd)
File “/opt/rockstor/src/rockstor/system/osi.py”, line 107, in run_command
raise Exception(msg)
Exception: Exception while running command([’/sbin/btrfs’, ‘fi’, ‘show’, ‘/dev/disk/by-id/ata-ST3000DM001-1ER166_W500QT0K’]): [Errno 24] Too many open files
[13/Aug/2017 20:37:52] ERROR [storageadmin.views.command:84] Exception while refreshing state for Pool(rockstor_rockstor). Moving on: Exception while running command([’/sbin/btrfs’, ‘fi’, ‘show’, ‘/dev/disk/by-id/ata-KINGSTON_SV300S37A60G_50026B72320277D8-part3’]): [Errno 24] Too many open files
[13/Aug/2017 20:37:52] ERROR [storageadmin.views.command:85] Exception while running command([’/sbin/btrfs’, ‘fi’, ‘show’, ‘/dev/disk/by-id/ata-KINGSTON_SV300S37A60G_50026B72320277D8-part3’]): [Errno 24] Too many open files
Exception: Exception while running command([’/sbin/btrfs’, ‘fi’, ‘show’, ‘/dev/disk/by-id/ata-KINGSTON_SV300S37A60G_50026B72320277D8-part3’]): [Errno 24] Too many open files
[13/Aug/2017 20:37:52] ERROR [storageadmin.middleware:32] Exception occured while processing a request. Path: /api/commands/refresh-snapshot-state method: POST
[13/Aug/2017 20:37:52] ERROR [storageadmin.middleware:33] Exception while running command([’/sbin/btrfs’, ‘subvolume’, ‘list’, ‘-u’, ‘-p’, ‘-q’, ‘/mnt2/pool-1’]): [Errno 24] Too many open files
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/core/handlers/base.py”, line 132, in get_response
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/views/decorators/csrf.py”, line 58, in wrapped_view
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/views/generic/base.py”, line 71, in view
File “/opt/rockstor/eggs/djangorestframework-3.1.1-py2.7.egg/rest_framework/views.py”, line 452, in dispatch
File “/opt/rockstor/eggs/djangorestframework-3.1.1-py2.7.egg/rest_framework/views.py”, line 449, in dispatch
return func(*args, **kwargs)
File “/opt/rockstor/src/rockstor/storageadmin/views/command.py”, line 323, in post
import_snapshots(share)
File “/opt/rockstor/src/rockstor/storageadmin/views/share_helpers.py”, line 139, in import_snapshots
share.name)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 485, in snaps_info
mnt_pt])
Exception: Exception while running command([’/sbin/btrfs’, ‘subvolume’, ‘list’, ‘-u’, ‘-p’, ‘-q’, ‘/mnt2/pool-1’]): [Errno 24] Too many open files
[13/Aug/2017 20:38:52] ERROR [storageadmin.views.command:84] Exception while refreshing state for Pool(pool-1). Moving on: Exception while running command([’/sbin/btrfs’, ‘fi’, ‘show’, ‘/dev/disk/by-id/ata-ST3000DM001-1ER166_W500QT0K’]): [Errno 24] Too many open files
[13/Aug/2017 20:38:52] ERROR [storageadmin.views.command:85] Exception while running command([’/sbin/btrfs’, ‘fi’, ‘show’, ‘/dev/disk/by-id/ata-ST3000DM001-1ER166_W500QT0K’]): [Errno 24] Too many open files
[13/Aug/2017 20:38:52] ERROR [storageadmin.views.command:84] Exception while refreshing state for Pool(rockstor_rockstor). Moving on: Exception while running command([’/sbin/btrfs’, ‘fi’, ‘show’, ‘/dev/disk/by-id/ata-KINGSTON_SV300S37A60G_50026B72320277D8-part3’]): [Errno 24] Too many open files
[13/Aug/2017 20:38:52] ERROR [storageadmin.views.command:85] Exception while running command([’/sbin/btrfs’, ‘fi’, ‘show’, ‘/dev/disk/by-id/ata-KINGSTON_SV300S37A60G_50026B72320277D8-part3’]): [Errno 24] Too many open files
[13/Aug/2017 20:38:52] ERROR [storageadmin.middleware:32] Exception occured while processing a request. Path: /api/commands/refresh-share-state method: POST
[13/Aug/2017 20:38:52] ERROR [storageadmin.middleware:33] Exception while running command([’/sbin/btrfs’, ‘subvolume’, ‘list’, ‘-s’, ‘/mnt2/pool-1’]): [Errno 24] Too many open files
File “/opt/rockstor/src/rockstor/storageadmin/views/command.py”, line 318, in post
import_shares(p, request)
File “/opt/rockstor/src/rockstor/storageadmin/views/share_helpers.py”, line 74, in import_shares
shares_d = shares_info(pool)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 421, in shares_info
o, e, rc = run_command([BTRFS, ‘subvolume’, ‘list’, ‘-s’, mnt_pt])
Exception: Exception while running command([’/sbin/btrfs’, ‘subvolume’, ‘list’, ‘-s’, ‘/mnt2/pool-1’]): [Errno 24] Too many open files
[13/Aug/2017 20:38:52] ERROR [storageadmin.middleware:32] Exception occured while processing a request. Path: /api/commands/refresh-snapshot-state method: POST
[13/Aug/2017 20:38:52] ERROR [storageadmin.middleware:33] Exception while running command([’/sbin/btrfs’, ‘subvolume’, ‘list’, ‘-u’, ‘-p’, ‘-q’, ‘/mnt2/pool-1’]): [Errno 24] Too many open files
share.name)
mnt_pt])
