Error activating AD
I get an error when trying to activate Active Directory support
Running Rockstor 5.0.9-0
setup Samba config with workgroup
click Submit
enter info in Active Directory config, have Enable enumeration checked
click Submit
switch AD from OFF to ON
error message pops up
Traceback (most recent call last): File "/opt/rockstor/src/rockstor/rest_framework_custom/generic_view.py", line 41, in _handle_exception yield File "/opt/rockstor/src/rockstor/smart_manager/views/active_directory.py", line 195, in post join_domain(config, method=method) File "/opt/rockstor/src/rockstor/system/directory_services.py", line 270, in join_domain return run_command(cmd, pinput=("{}\n".format(config.get("password"))), log=True) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/opt/rockstor/src/rockstor/system/osi.py", line 289, in run_command raise CommandException(cmd, out, err, rc) system.exceptions.CommandException: Error running a command. cmd = /usr/sbin/realm join --membership-software=samba -U administrator hq.sutter.com. rc = 1. stdout = ['Password for administrator: ', '']. stderr = ["realm: Couldn't join realm: Failed to enroll machine in realm. See diagnostics.", '']
@edc welcome to the Rockstor community. Have you tried to join the AD domain using the command line directly? A related, but not quite the same, thread was also going through various troubleshooting in the domain space. If @Flox or @ocelot11 have some insight to share here, since this is definitely not my domain expertise.
Dunno if you ever figured this out, i had given up with mine for a while. I just came back for a different issue and saw myself tagged. Not to necro, but if anyone ever has this issue, mine was actually because kerberos stopped supporting older encryption types by default and it causes a ton of weird errors. Edit your krb5.conf to allow weaker encrypt types and allow AES 256, 128, and rc4.
