Im trying to build a nextcloud rock-on based on this docker container: https://hub.docker.com/r/wonderfall/nextcloud/ with mariadb. I wrote a nextcloud.json (see below) file and saved it in “/opt/rockstor/rockons-metastore/” directoy. When I hit “Update” in the rock-on web ui I get the follwing error. What is wrong with my json-file?
Errors occurred while processing updates for following Rock-ons. Nextcloud: DContainer matching query does not exist.
File “/opt/rockstor/src/rockstor/storageadmin/views/rockon.py”, line 105, in post
return func(*args, **kwargs)
File “/opt/rockstor/src/rockstor/storageadmin/views/rockon.py”, line 319, in _create_update_meta
co = DContainer.objects.get(rockon=ro, name=cname)
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/manager.py”, line 127, in manager_method
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py”, line 334, in get
self.model._meta.object_name
DoesNotExist: DContainer matching query does not exist.
/opt/rockstor/rockons-metastore/nextcloud.json :
"Nextcloud": {
"container_links": {
"owncloud": [
"name": "db_nextcloud",
"source_container": "db_nextcloud"
"containers": {
"nextcloud": {
"image": "wonderfall/nextcloud",
"tag": "latest",
"launch_order": 2,
"ports": {
"8888": {
"description": "OwnCloud WebUI port. Suggested default: 8888",
"host_default": 8888,
"label": "WebUI port",
"protocol": "tcp",
"ui": true
"volumes": {
"/config": {
"description": "Choose a Share for Nextcloud configuration (e.g. config.php).",
"label": "Config Storage",
"min_size": 1073741824
"/data": {
"description": "Choose a Share for Nextcloud data.",
"label": "Data Storage",
"/apps2": {
"description": "Choose a Share for Nextcloud downloaded apps",
"label": "App Storage",
"environment":{
"TZ":{
"description":"the system/log timezone (default : Etc/UTC)",
"label":"Timezone"
"ADMIN_USER":{
"description":"username of the admin account (default : admin)",
"label":"Admin User"
"ADMIN_PASSWORD":{
"description":"password of the admin account (default : admin)",
"label":"Admin Password"
"DB_TYPE":{
"description":"must be set to 'mysql'",
"label":"Database Type"
"DB_NAME":{
"description":"must be the same as on db_nextcloud",
"label":"Name Of Database"
"DB_USER":{
"label":"Name of Database User"
"DB_PASSWORD":{
"label":"Database Password"
"DB_HOST":{
"description":"must be set to 'db_nextcloud'",
"label":"Database Host"
"db_nextcloud": {
"image": "mariadb",
"tag": "10",
"launch_order": 1,
"volumes": {
"/var/lib/mysql": {
"description": "Choose a Share for Nextclouds's mysql database.",
"label": "Database Storage",
"environment":{
"MYSQL_ROOT_PASSWORD":{
"description":"User nextcloud database password",
"label":"Mysql Root Password"
"MYSQL_DATABASE":{
"description":"User nextcloud database name",
"label":"Mysql Database Name"
"MYSQL_PASSWORD":{
"label":"Mysql Password"
"version": "latest stable",
"description": "Secure file sharing and hosting",
"icon": "https://nextcloud.com/wp-content/themes/next/assets/img/common/nextcloud-square-logo.png",
"more_info": "<p>More info...</p>",
"ui": {
"https": true,
"slug": ""
"website": "https://nextcloud.com/"
Thanks in advance!
