VINOTH
(VINOTH)
June 6, 2017, 10:40am
1
Error running a command. cmd = /sbin/btrfs filesystem show /dev/disk/by-id/sda3. rc = 1. stdout = [’’]. stderr = [‘ERROR: not a valid btrfs filesystem: /dev/disk/by-id/sda3’, ‘’]
phillxnet
(Philip Guyton)
June 6, 2017, 10:51am
2
@VINOTH Welcome to the Rockstor community.
This error is due to no serial on the system disk. Please see the most recent forum thread on this issue and how you might add a serial via your virtual machine manager (presumably VMWare):
[Add Storage-> scan = error message]
Web-UI scr…
We have a pending rockstor-doc pull request:
rockstor:master ← phillxnet:157_Add_drive_serial_requirements_to_min_sys_spec
opened 01:07PM - 26 May 17 UTC
Add a single line to the Quick Start page in the "Minimum system requirements" t… o indicated the requirement for unique serial numbers with a reference to this pertaining to VM systems not real hw.
Displays as expected in Chrome and Firefox.
Tested using 64bit Sphinx v1.4.8.
No errors indicated.
Fixes #157
@schakrava Ready for review.
to add this to our Minimum system requirements
Hope that helps. Essentially an artefact of VMWare failing to give drives a unique identifier by default such as is the case with real drives.
