File “/opt/rockstor/src/rockstor/storageadmin/views/share.py”, line 206, in post
add_share(pool, sname, pqid)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 701, in add_share
toggle_path_rw(root_pool_mnt, rw=True)
File “/opt/rockstor/src/rockstor/system/osi.py”, line 657, in toggle_path_rw
return run_command([CHATTR, attr, path])
CommandException: Error running a command. cmd = /usr/bin/chattr -i /mnt2/HORNITOS. rc = 1. stdout = [‘’]. stderr = [‘/usr/bin/chattr: Read-only file system while setting flags on /mnt2/HORNITOS’, ‘’]
@Hornitos welcome to the Rockstor community.
Since the error message does only show the symptoms, can you provide a little more context when you ran into this error message?
What version of Rockstor are you using?
What were you trying to do when this error occurred?
Did this happen shortly after installation, or had the server been running a while?
Whatever else you think could help the investigation.
