This happens when I try to create a share on a newly created pool.
The pool is created using RAID 6 using 5 x 10GB SAS drives that are connected to a HBA.
[write here]
File "/opt/rockstor/src/rockstor/storageadmin/views/share.py", line 206, in post
add_share(pool, sname, pqid)
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 701, in add_share
toggle_path_rw(root_pool_mnt, rw=True)
File "/opt/rockstor/src/rockstor/system/osi.py", line 657, in toggle_path_rw
return run_command([CHATTR, attr, path])
File "/opt/rockstor/src/rockstor/system/osi.py", line 227, in run_command
CommandException: Error running a command. cmd = /usr/bin/chattr -i /mnt2/MainStorage. rc = 1. stdout = ['']. stderr = ['/usr/bin/chattr: Read-only file system while setting flags on /mnt2/MainStorage', '']
