I disabled NetworkManager and enabled wicked, and this happened
As above
File “/opt/rockstor/src/rockstor/storageadmin/views/network.py”, line 236, in get_queryset
self._refresh_devices()
File “/opt/rockstor/.venv/lib/python2.7/site-packages/django/utils/decorators.py”, line 185, in inner
return func(*args, **kwargs)
File “/opt/rockstor/src/rockstor/storageadmin/views/network.py”, line 201, in _refresh_devices
dmap = sysnet.get_dev_config(sysnet.get_dev_list())
File “/opt/rockstor/src/rockstor/system/network.py”, line 47, in get_dev_list
o, e, rc = run_command([NMCLI, “-t”, “-f”, “device”, “device”])
File “/opt/rockstor/src/rockstor/system/osi.py”, line 246, in run_command
CommandException: Error running a command. cmd = /usr/bin/nmcli -t -f device device. rc = 8. stdout = [‘’]. stderr = [‘Error: NetworkManager is not running.’, ‘’]
I’m afraid NetworkManager is one of Rockstor’s expectations as it uses it to interact, read, and write anything network-related. Making it work with wicked would require substantial modifications to many core functions so it would not be something I would advise.
May I ask if there is anything in particular that you would like to accomplish? Chances are, it can also be accomplished using NetworkManager and we would more more than happy to assist where we can.
@kensee as @Flox pointed out, Rockstor is currently built around Network Manager, since it was historically designed on the now defunct CentOS system. The transition to OpenSUSE kept Network Manager in place, since we have quite a bit of other technical debt to address first and it would require a major redesign.
What is your use case that you need to use YAST2 to manage your network settings, that are not addressed through the Rockstor UI or the nmcli command line options?
