I can’t schedule any scrubs. I am running 3.9.1-13
Trying to schedule a scrub of any pool fails in the same way. Red is the name of the pool I tried to schedule for that error report.
File "/opt/rockstor/src/rockstor/smart_manager/views/task_scheduler.py", line 151, in post
crontab, crontabwindow, meta = self._validate_input(request)
File "/opt/rockstor/src/rockstor/smart_manager/views/task_scheduler.py", line 47, in _validate_input
if not Pool.objects.filter(id=meta['pool']).exists():
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py", line 679, in filter
return self._filter_or_exclude(False, *args, **kwargs)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py", line 697, in _filter_or_exclude
clone.query.add_q(Q(*args, **kwargs))
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/query.py", line 1310, in add_q
clause, require_inner = self._add_q(where_part, self.used_aliases)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/query.py", line 1338, in _add_q
allow_joins=allow_joins, split_subq=split_subq,
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/query.py", line 1209, in build_filter
condition = self.build_lookup(lookups, col, value)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/query.py", line 1102, in build_lookup
return final_lookup(lhs, rhs)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/lookups.py", line 105, in __init__
self.rhs = self.get_prep_lookup()
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/lookups.py", line 143, in get_prep_lookup
return self.lhs.output_field.get_prep_lookup(self.lookup_name, self.rhs)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/fields/__init__.py", line 727, in get_prep_lookup
return self.get_prep_value(value)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/fields/__init__.py", line 985, in get_prep_value
return int(value)
ValueError: invalid literal for int() with base 10: 'red'
