Error trying to discover disks right after install
Cannot discover storage
Brand new install on VMware. OS is installed on /dev/sda. /dev/sdb was meant for storage.
[root@Rockstor ~]# fdisk -l
Disk /dev/sda: 17.2 GB, 17179869184 bytes, 33554432 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk label type: dos
Disk identifier: 0x000ad405
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 1026047 512000 83 Linux
/dev/sda2 1026048 4382719 1678336 82 Linux swap / Solaris
/dev/sda3 4382720 33554431 14585856 83 Linux
Disk /dev/sdb: 536.9 GB, 536870912000 bytes, 1048576000 sectors
File “/opt/rockstor/src/rockstor/storageadmin/views/disk.py”, line 377, in post
return func(*args, **kwargs)
File “/opt/rockstor/src/rockstor/storageadmin/views/disk.py”, line 322, in _update_disk_state
p.uuid = btrfs_uuid(dob.name)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 1055, in btrfs_uuid
[BTRFS, ‘filesystem’, ‘show’, ‘/dev/disk/by-id/%s’ % disk])
CommandException: Error running a command. cmd = /sbin/btrfs filesystem show /dev/disk/by-id/sda3. rc = 1. stdout = [’’]. stderr = [‘ERROR: not a valid btrfs filesystem: /dev/disk/by-id/sda3’, ‘’]
@Sergei_Genchev Welcome to the Rockstor community.
This is due to the minimum system requirements for Rockstor not having been met by VMware by default.
Please see our Quick start doc section specifically the Minimum system requirements:
  • All drives must have unique serial numbers (real drives do); not all VM [*] systems default to this
where the [*] references the following inline note:
[*] For VMware ensure you have disk.EnableUUID=“true” in your .vmx file
