After installing Rockstor and attempting to do the initial setup via the web UI, after filling out the forms and clicking “Submit” the error appears. The user is created and the error appears. Can’t progress past this point.
Create a rockstor bootable USB as per the instructions. Install it, boot , go to web ui IP, encounter error.
File “/opt/rockstor/src/rockstor/storageadmin/views/appliances.py”, line 114, in post
appliance = Appliance(uuid=hostid(), ip=ip,
File “/opt/rockstor/src/rockstor/system/osi.py”, line 1088, in hostid
return ‘%s-%s’ % (run_command(HOSTID)[0][0], str(uuid.uuid4()))
File “/opt/rockstor/src/rockstor/system/osi.py”, line 90, in run_command
raise Exception(msg)
Exception: Exception while running command([‘/’, ‘u’, ‘s’, ‘r’, ‘/’, ‘b’, ‘i’, ‘n’, ‘/’, ‘h’, ‘o’, ‘s’, ‘t’, ‘i’, ‘d’]): [Errno 13] Permission denied
